Question about Iris Readiris Pro 10
Unable to recognize scanner - Iris Readiris Pro 10
Replaced the toner cartridge and unit will not recognize new cartridge
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Mar 08, 2012 | HP Laserjet M2727nf Multifunction Printer
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
Have Kodak 1500d. Import with photoshop turns off computer.
I have library of photos with HP. How do I import them to Kodak. It just comes up with Snapfish.
Apr 14, 2009 | Kodak Digital Science 1500D Path-Through...
Microtek ArtixScan 4000tf - pc won't recognise scanner
http://202.39.72.2/installer/windows/swprotx/swprotx_7100.exe - driver
if helped rate fixya
Apr 09, 2009 | Microtek ArtixScan 4000tf Film Scanner
Panasonic DMC-FZ18. Unable to download pictures to Camera and Scanner Wizard -
It would appear that DMC-FZ18 cannot reliably communicate with Windows XP. However if SD card is removed from camera and connected directly to computer there is no problem.
Jul 26, 2008 | Cameras
Unable to scan, Unable to get the scanner to even be found (but twice)
Do you have a spare USB cable. Sometimes if that goes bad, that happens.
Try another available UBS port as well.
Jun 16, 2008 | Microtek ScanMaker 4900 Flatbed Scanner
Scanner not recognizing software
try opening the scanner from the START-ALL PROGRAMS-HP-ALL IN ONE
Jan 11, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning problem
I?m afraid helping you would be impossible unless you give us all the relevant details: - What is the exact model number of the scanner? - What computer are you using? - Does the computer recognize the scanner? - If yes, what error message are you getting?
Feb 22, 2006 | Epson Stylus CX3200 All-In-One InkJet...
How to clear error code 0000003d
Is it a USB scanner? Look in System information\device manager to see if your scanner is at all recognized by the computer. If not, install the drivers that came with the scanner. If the drivers are already installed, use it with another USB cable to see if your own is the culprit. If the problem persists, replace the USB card.
Jan 30, 2006 | Panasonic KV SS905C Path-Through Scanner
Top Iris Office Equipment & Supplies Experts
xalint1
xalint1
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
