Question about GPX CRCD6306DT Clock Radio
How do I get the cd to play with sound...the cd spins around but what buttons do I press to get this thing to play so I hear it?
When playing from the AUX (i.e. iphone), can't hear from both speakers, only one; but when playing from a CD, the sound is fine. Any suggestions/advice/help? The odd thing is that if I press down
hi, seems like you may have a faulty aux jack socket(if the socket is mounted onto the face) or you may have some dry joints on the socket, or even a cracked pc board around the aux socket connections. also try cleaning the face connection pins both on the unit and on the face. if you not technically minded, check out you jvc repair center. cheers!
May 24, 2012 | JVC Kd-r310 Car CD/ MP3 Player
Laptop turns off after a second
One second after your press the power button or one second after it gets the the windows desktop? When you press the power button do you hear the fan running, see any lights, hear the disk drive spinning, hear the cd rom drive click once and see the light for about 2 seconds on the cd rom drawer? If all the previous is seen or heard it means you are getting power and it's trying to boot. If you see or hear nothing at all it means your power cord is probably bad. On most laptops once you plug the power cord in you should see a light someone on the laptop, if not the cord is bad. Also on some AC Adapter Power Cords they will have an indicator light on the adapter that lets you know it's functioning. It really sounds like your power cord went bad and the last time you were able to operate you were operating off your battery which is completely drained since the cord could not recharge it. One last thing to try is remove the power cord and battery from the laptop. Press and hold the power button for 30 seconds, then plug on the power cord back it and press the power button. if it boots you can put the battery back in.
Mar 20, 2012 | Computers & Internet
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
Cannot turn off the machine
Try cleaning the laser with a cleaning cd.
May 20, 2009 | Sony D-NE20 Personal CD Player
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Unit won't read CD
The thing with Head Units is unless you take it to a guy that specialises in electronics to give the full problem, it's better to replace the unit. Also repair might cost a fortune. Can you get warranty?
Feb 11, 2008 | JVC KD-LX30 CD Player
Help
Lift up the platter underneath should be a belt (black rubberband) on the platter. Once you find it leave it there put the platter back on, pad off. With the player off put the belt over the brass motor spindle.
Dec 21, 2007 | Gem Sound DJ-2100 Turntable
GPX CRCD6306DT Clock Radio Logo
14 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
