Question about RAYMIH20LTCB15 Infrared Sensor with 22:1 Optics and 15m Cable
22 TP sensor Circuit - Out of Range Low 1995 Saturn sc2 (itwont start)
  • 20,706 Answers
Raytek?
TPS sensor output is low, the ecu never lies about that.
but can be
1: lost power to TPS.,usually 5v, if not 5v ECU is bad,(or wire cut)
2: not calibrated per the FSM,most old cars need calib, (physicaly
3: Bad stuck low TPS.
4:
Posted on Oct 23, 2013
What dose it mean when engin light falshes contstantly
Flashing Diag Code P0122
TP circuit low input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 below 0.10 V after engine start, PCM determines
that TP circuit has a malfunction.
POSSIBLE CAUSE
• TP sensor malfunction
• Connector or terminal malfunction
• Open circuit between TP sensor terminal C and PCM terminal 89
• Short to ground circuit between TP sensor terminal C and PCM terminal 89
• Open circuit between TP sensor terminal A and PCM terminal 90
• Short to ground circuit between TP sensor terminal A and PCM terminal 90
• PCM malfunction
Flashing Diag Code P0123
TP circuit high input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 is above 4.77 V after engine start, PCM determines
POSSIBLE CAUSE
• Open circuit between TP sensor terminal B and PCM terminal 91
• Short to reference voltage (Vref) supply circuit between TP sensor terminal C and PCM terminal 89
• PCM malfunction
Jun 26, 2014 | 2000 Mazda Protege
Codes for a1992 Saturn SC Coupe
code 22 is throttle position sensor voltage
code 32 is EGR system fault
code 34 is MAP circuit voltage out of range low
code 45 is oxygen sensor indicates rich exhaust
code 48 and 53 are for the transaxle and both point to the PCM
May 16, 2012 | 1992 Saturn SC
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
WHY IS THE SERVICE ENGINE LIGHT ON IN MY SATURN??
The Check Engine light will light when the ECU stores a trouble code.
Counting the Flashes
To retrieve trouble codes, turn the ignition key to the "on" position with the engine OFF.
The Check engine light will flash many short blinks. The total number of blinks equals the code number. For example, flash,pause, flash,flash = code 12.If more than one code is stored, the Check engine light will flash the codes in sequence (lowest to highest) with a pause between each code. The codes will repeat until the key is turned to the OFF position.
11 Transaxle codes present 12 Diagnostic check only 13 Oxygen sensor circuit 14 Coolant sensor/high temperature 15 Coolant sensor/low temperature 17 PCM fault - pull-up resistor 19 6X signal fault (92-95 models) 21 Throttle position sensor-voltage high 22 Throttle position sensor-voltage low 23 IAT circuit low 24 VSS circuit-no signal 25 IAT circuit-Temp out of high range 26 Quad driver output fault 32 EGR system fault 33 MAP sensor - voltage out of range high 34 MAP sensor - voltage out of range low 35 IAC - rpm out of range 41 Ignition control circuit-open or shorted 42 Bypass circuit - shorted or open 41/42 IC control circuit grounded/bypass open 43 Knock sensor circuit shorted or open 44 O2 sensor indicates lean condition 45 O2 sensor indicates rich condition 46 Power steeringpressure circit(91 models)open or shorted 49 High idle indicates vacuum leak 51 PCM memory error 53 System voltage error 55 A/D error 58 trans fluid temperature too high 59 Trans fluid temperature too low 66/67 A/C pressure sensor 81 ABS message fault 82 PCM internal communication fault
Mar 10, 2010 | 1992 Saturn SL2
Code: P0133 - O2 Sensor Circuit Slow Response Bank 1 Sensor 1
is this a 4 or 6 cylinder?
if a 4 cylinder it will only have 2 o2 sensors
V6 will have 4 o2 senors which the sensor will be the right side of the engine first sensor.
1st sensor on exhaust, I recommend if you change one change all, as this will make the computer when it rechecks the system you have all clean/fast responding sensors.
if you have a slow response it means the sensor is dirty and not reading well, which is usually caused by minor misfires that the engine computer dismisses, so a tune up would be recommended too.
May 06, 2009 | 2001 Saturn SC
Saturn SC1 SC2 1995-1999 Radio Wire/Wiring diagram
For the 1995 SC2:
http://www.modifiedlife.com/1995-saturn-sc2-car-radio-wire-diagram/
Other links on the left side of that page.
HTH.
Mar 08, 2009 | 1995 Saturn Sc
99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
Feb 24, 2009 | 1993 Saturn SC1
Diagnostic code for '95 Saturn SL
My manual shows----- code 22 is throttle position sensor, and code 83 is low engine coolant.
Jan 22, 2009 | 1995 Saturn Sl
RAYMIH20LTCB15 Infrared Sensor with 22:1 Optics and 15m Cable Logo
Top Raytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Raytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
