Question about Rowenta DZ5080 Iron with Auto Shut-off
Temperature dial fell off - Rowenta DZ5080 Iron with Auto Shut-off
Label indicating the heat settings fell off the dial on my rowenta DM880
Not necessary To due the thermostat inside. you mus recalibrated.
God bless you
Jul 19, 2012 | Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
I bought a Durabrand TSK-7538S Steam Iron for $12 at Wal-Mart. It's fine but the "instructions" are poor. I can't figure out how to set the temperature. I mean, I know you turn the dial, but...
okay. thats not a bad question, i got the same iron, and i know what your're talking about. the "line" you're talking about is not a line at all, it's actually a tiny plastic indicater at the bottom of the dial. it's blue too, so you cant see it, so feel on it with your finger. =) email me if i helped. solacewishes@yahoo.com
Apr 21, 2008 | Conair Compact Garment Steamer Iron
Dial stops at "silk."
if the iron is under warranty send it back to the company.if not take down the iron it has a broken part that is stopping it from moving properly.good luck.
Apr 02, 2007 | Rowenta Perfect Iron
Rowenta DZ5080 Iron with Auto Shut-off Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
