Re-synching key fob to alarm congroller
After battery in both car and key fob ran down, can't get key fob to operate door locks
    Problem Solver:
  • 3 Answers
More than likely you will have to re-sync your keyfob to the car. Your owners manual may have the steps needed to do this. What year/make/model of vehicle is it?
Posted on Oct 23, 2013
Testimonial: "It is a 2000 Porsche Boxter s. I saw a fixya answer for a similar problem for a 911 from e-guru. Could a similar procedure work for a Boxter?"
How to troubleshoot central locking.
Wondering if the door lock mechanisms needs greasing
like some form of resistance to movement may put the power locking out of kilter ..
May 15, 2016 | Mitsubishi Lancer Cars & Trucks
Re-setting synch between key fob and alarm controller on porsche boxter
change the battery in the keyunit.u need to stick a small flat screwdriver between the two parts to get it open.
Oct 22, 2013 | Computers & Internet
1998 altima key fob won't lock doors and alarm doesn't work
More than likely the battery is dead or the remote has lost programming.
Jul 16, 2013 | Cars & Trucks
Left lights on ,and ran down battery. When i try to jump start, alarm goes off,key fob wont work till battery charges tried putting key in ignition and turning key, tried locking and unlocking door. what...
Find the alarm and disconnect it, or locate the fuse to the alarm and remove it. Then you can charge the battery without all the noise. Once the battery is charged, hook the alarm up and disarm it with the remote.
Dec 28, 2010 | Kia Spectra5 Cars & Trucks
1999 porsche 996 replaced key fob battery disconnected battery now trunk releses are locked and cant access battery.How do you open frt trunk manually
Assuming the car battery is ok (if not, buy a male to male cigarette lighter at the auto store and connect to another car until charged enough to unlock the doors...but don't try to crank the ignition!). The trunks won't open if the battery went dead with the alarm set because arming the alarm physically locks the releases.
Sounds like the key code is switched off because you replaced the key fob battery. Try unlocking the car manual with the key in the door lock. Then switch the ignition on to reactive the keyless entry. If this does not work, you might also try pressing the fob unlock button with the key in the door lock until the dash led flashes.
Jun 10, 2010 | 1999 Porsche 911 Carrera
Changed oil and cleaned battery cables.Started car up. Ran for 2 seconds security alarm went off car shut down.no power to fuel pump.Is there some way to reset the fuel pump
You need to reset the alarm system.That can be done with the remote entry key fob or by locking then unlocking the drivers door with the ignition key with all doors closed.This is for a factory alarm system.Also check the inertia switch,should be in the trunk,on the side with a push button top.Push button.If already down its not tripped.
Apr 17, 2010 | 2000 Mercury Cougar
Everytime I lock the car using the key fob, about 30 seconds later the alarm sounds but the lights do not flash and the horn does not sound. Only when I unlock the car will it go off. I have disconnected...
you may have a bad door switch, theres a switch on the drivers door lock, when door is unlocked with fob or key the switch is activeated to shut alarm down,the lock moves to hit switch with key or fob,so if the switch is bad it will not shut down alarm, i would start there,door panel has to be remove,then latch has to be remove to get to switch, then test with a meter see if it opens and closes the connection, hope this helps.
Dec 26, 2009 | 2000 Jaguar S-Type
Pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
Oct 06, 2009 | 2001 Chrysler PT Cruiser
190d merc fob does not work operating with key disconnected battery alarm came on with hasards how do i fix
If you need to shut off the alarm without the fob insert your key in the drivers door lock and lock and unlock the car My 89 300TE does this on occasion this wil reset the alarm to off to rearm the alarm lock the car again
Jul 07, 2009 | 1991 Mercedes-Benz 190
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
