Question about Montgomery Ward Heating & Cooling
Wards portable space heater 89 21300 fan is broken
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Find a phone number for welbilt space heaters
Hi
you may be interested in the following link to Welbilt.
Trust this helps, regards Alan
Welbilt Corp History
Feb 11, 2015 | Comfort Zone NEW 09 Electric Portable...
I have an old montgomert ward space heater mod 313 and would like to be able to us it, but when it is running you can not stay in the same room.\r\nThe fumes are terrible. I had to adjust the air to reduce...
Sounds like your "old Montgomery Ward Space Heater" has given up the ghost. Frankly, it's time to replace it. Even under the best conditions (even with routine maintainence) they don't last forever. Continuing to try to use it, becomes a safety & health issue.
Jan 28, 2011 | Montgomery Ward (223600UP) Heater
Flashing A05 message
Hi. Did you see it http://www.fixya.com/support/t6866069-comfort_zone_infrared_hearter ? It's you possible decision...
Ted Infrared Heaters Guide
Dec 04, 2010 | Comfort Zone NEW 09 Electric Portable...
I have a Mont Ward 500 gas heat system that the blower keeps running, Im thinking it's the thermostat. If that's it, which kind should I get?
There is a pull switch on the Fan Limit Control. Check to see if it is pushed in. Pull it Out for normal operation.
Nov 13, 2010 | Montgomery Ward (223600UP) Heater
Our comfort zone continues to switch over to Celsius, how can I switch it back to Farenheit?
Hold Down adn Enter keys for 3 seconds. Had the same problem, found the answer on this web site.
Oct 28, 2010 | Comfort Zone NEW 09 Electric Portable...
I can't change from C to F.
Hold DOWN and ENTER keys for 3 seconds. Had the same problem, found the answer on this web site!
Oct 26, 2010 | Comfort Zone NEW 09 Electric Portable...
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
Settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Heating & Cooling Logo
52 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
