Question about Kenwood KAC-7204 Car Audio Amplifier
A screw driver touched the pos and grd now the red led comes on and goes off no sound
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Blew the transistour
Posted on Nov 07, 2013
How to attach 6 red wires on 1998 ford contour
The biggest diameter wire goes to biggest fuse. All the wires to the fuse box are the same. Doesn't matter which goes where. The alternator wire goes to the side of the panel. 175 amp fuse.
Feb 27, 2016 | 1998 Ford Contour
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
2004 holden rodeo key wont unlock doors remote or key lights flashing to indicate button pushed
sounds like the battery in the heart shaped remote is flat
green led for unlock or
red led for lock should light up on remote when pressing button if these led lights are not working possibly battery flat
battery part number cr2030
you can get this at a lot of different shops for a couple of dollars and replace yourself
insert small flat blade screw driver in slot where key ring goes and case opens.
Sep 03, 2011 | Isuzu Rodeo Cars & Trucks
Hi, I have a Cobra 29 NW ST CB Radio and I was wondering something about changing the stock burnt out bulb to an LED. Does it matter which wire goes to the negative side of the LED and which one is the...
LED's do matter how they're installed.
Test your LED leads w/ a batt. first before soldering in you 29 board.
Look at you existing leads from you burnt out bulb. One red?
Then its your Pos terminal. when your LED lights up on your Batt. test you'll know which one is the POS/NEG legs. then resolder it into your board.
Mike
Dec 31, 2010 | Cobra 29 LTD CB Radio
Need drawing How to Replace 1993 Oldsmobile 88
yes just jack up so can slide under, most to remove will be the cable brackets which hold them down, not hard to do
Feb 05, 2010 | 1993 Oldsmobile Eighty Eight
TV won't come on, the red LED keeps blinking
sounds like you have a solder joint thats touching another one, recheck your solder and make sure theres no broken solder joints else where.
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
No power turn on??
Does the voltage at the battery drop when you connect 12v to the remote terminal?
If not, there is too much resistance in the power/ground wiring.
If the voltage drops at the battery, either the battery is weak or the amp is drawing excessive current.
Dec 03, 2007 | Kenwood KAC-728S Car Audio Amplifier
NO SOUND
HELLO MR GRUMPY I HAVE A SOLUTION FOR THIS IF YOU CAN DO IT YOURSELF ALL YOU NEED IS A PP9 6 VOLT BATTERY 2 WIRES AND 2 PINS THIS INJECTES 6 VOLTS ..... THE 360,S SOUND COMPATABLITYS ARE __Audio __Multi channel surround sound output __Supports 48khz 16-bit audio __320 independent decompression channels __32 bit processing __256+ audio channels ....__..........................................__PLEASE DICONNECT ALL RF LEADS /POWER SUPPLYS/WIRED PADS FROM 360 BEFORE TRYING THIS AND ANY DISK IN THE CONSOLE TAKE 360 APART TILL YOU HAVE THE 360 BOARD IN FRONT OFF YOU USE THE GRAPH ON THE BOARD I HAVE POSTED AND FIND THE PART ON THE PIC LOCATION 8N/8P MEANING 8 POSITIVE 8 NEGITIVE ......__NEXT BATTERY WITH 1 WIRE COMING FROM NEG AND 1 WIRE COMING FROM POS YOU ONLY HAVE TO TOUCH POS WIRE TO POS LOCATION ON BOARD AND NEG TO NEG ON BOARD BOTH AT THE SAME TIME NOW PUT YOUR 360 BACK TOGETHER ....WARNING DONT PUT NEG TO POS OR VICE VERSA I WONT BE HELD RESPONSIBLE FOR ANY DAMAGERS ETC
Jun 01, 2007 | Microsoft Xbox 360 Console
Kenwood KAC-7204 Car Audio Amplifier Logo
29 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
