Question about Frigidaire Washing Machines
My Frigidaire washer control panel thinks the door is open how do I fix this?
  • Official Brand Answer
  • 4,342 Answers
Hi Susan, thank you for your post!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. Contact a professional to move forward accurately.
Posted on Oct 23, 2013
SUPERMAN_B_1
  • 294 Answers
SOURCE: door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
Posted on Mar 29, 2009
  • 58 Answers
SOURCE: Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Posted on May 05, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
  • 33 Answers
SOURCE: The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Posted on Apr 29, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have an Frigidaire Affinity
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 01, 2011
What is code E41 on a Frigidaire Affinity ATF800FS. THE DOOR IS LOCK BUT THE DOOR LOCK INDICATOR WONT LIGHT UP & THE WASHER WONT SPIN
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Aug 03, 2015 | Frigidaire Washing Machines
My frigidaire atf6000e comes up with error code 48 how do I fix that
Good Morning Joseph, thank you for your inquiry!
From what you have described your Frigidaire washer is displaying an error code of "48" and you would like to fix the issue. An "E48" error code stands for your control board thinking the door is closed. This could be a possible problem with your door lock assembly or the control panel. You may want to check the door latch to make sure there is no visible damage or loose wires. I would recommend consulting with a professional for proper repairs if the latch is not damaged. I hope this information is helpful. -Matt
Mar 14, 2015 | Frigidaire Washing Machines
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidaire front load washer that gave me a error 47 code. what can that be.
The circuit thinks the unit is in spin cycle - Remove the door lock assembly and measure the resistance of the PTC. Shorted or open, defective door lock assembly. Reads around 1500 ohms, defective Main Control Board.
Aug 19, 2012 | Frigidaire ATF6000ES Front Load Washer
Hi Mr. Barry Coates, I have frigidaire ATF 6700FS front load washer. I am having problem with error code E41 and all time it shows me PAU. I tried all the solution on this site but nothing works. Could...
E41 - Control board thinks the door switch is open.
PAU means PAUSE in the cycle; if you are try all methods, I assume that the control panel needs to be replaced.
Check in this link your Control Board Replacement
Hope helps.
Oct 12, 2011 | Frigidaire ATF6700FS Front Load Washer
When I start my washer, it runs for a few minutes and then shuts down, When I try to reset it flashes an "E41" on the panel.
I have the same washer the code for that is control board thinks the door switch is open..to repair it said to check pressure switch....something about these washers front door problems.....
Jun 20, 2011 | Frigidaire GLTF2940F Front Load Washer
Frigidaire ATF6000FS1 Error Message E41. I set up the machine, hit the start button, and I only get he PAU note across the screen. The washer will not start up. Ran the Diagnosis and come up with E41. ...
Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
Apr 08, 2011 | Frigidaire Washing Machines
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity wont start
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
139 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
