Speaker sound issue
Sound from certain speakers coming in and out, a tap on side or top of them fixes temporarily but continues to happen after again at random times ...
  • 341 Answers
It sounds like something has loosened up inside the speaker. Try putting the speaker on it's side and see if the intermittent problem goes away. If it does, that would indicate that there is something that needs to be tightned or re-soldered to solve the problem.
Posted on Oct 23, 2013
4 Suggested Answers
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
SOURCE: Left speaker sometines has no sound? Please help
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Posted on Jul 19, 2009
SOURCE: JBL Creature 2.1 Left Speaker not working
Hiya
Too late to resolve the original poster's worries, I can assume, but I arrived here when searching on account of the same problem and resolved it. This is going to sound implausibly condescending, I'm afraid (and excuse th elack of technical terminology!)...
I couldn't get my left speaker to work exactly as above, but then looked carefully at the shape of the respective cables leading to the sub. You have to fit the triangle shape of the lead into the triangular shape of the hole. The speaker CAN be connected what *feels* like correctly, but is in fact connected incorrectly (ie, not all the way in).
This is more a problem with the left speaker than the right since it's a triangle and the right is a square, and can be a little fiddly.
Anyone else experiencing the same problem should probably take a quick moment just to check this isn't it! :)
Posted on Feb 26, 2010
Sound is only coming out of one side of my earthquake sub. Could I have blown the other side? Thank you
That's certainly a possibility, but there are others, like a wire coming out of the terminal, etc. First step is to pull the speaker out and check it with an ohm meter. If there's no continuity it's blown.
Jun 11, 2016 | Earthquake Sound Audio Players & Recorders
Sub12 Venue making clicking and loud noises
I would normally ask here "with or without signal going into it"
If it's making noises with no signal, the amplifier needs servicing
if it's when there is signal present, it could be the amp OR the speaker itself.
The speaker of course can be replaced with almost any 12" woofer of the same handling capacity.
Again, if it's the amp, the amp will need to be serviced.
To find out which is the issue in scenario 2, unscrew and remove the woofer and temporarily connect another speaker, putting a low to moderate signal (careful you don't blow the speaker you have temporarily connected).
If you get the same clicking/noises etc. then the amp is the fault. If not, the speaker is the fault.
Feb 26, 2011 | JBL Venue SUB12 Subwoofer
Headphone jack must be moved around to get right speaker working
You will find that sound comes from the right side speaker only when it is bent at a certain point. By trial and error you can roughly locate the point. Then you can cut the wire at that point, cut 1 inch each from both ends, strip the cables, and connect the conductors. What has happened is, due to unusual bending, the conductors to the right-side speaker has damaged (broken). After roughly locating the place and removing 1 additional inch each, you will remove the wire section with the broken terminal. Now you can strip the wires and make the connections again. If you are not good at stripping and soldering wires, better to to take it to an electrician. (You need to take only the headphone pin and parts attached to it). This repair won't cost much. Good luck!
Jun 25, 2009 | Logitech Z-2300 Computer Speakers
One speaker works all the time the others only sometimes
Could be intermittant wiring issue or the speaker itself.
If you have another spare car speaker you can hook up temporarily, I'd start there. Disconnect one of your "bad" speakers and hook up a known good one. If the temp. speaker works OK all the time, then you know you wiring is okay.
Let me know if more ?s!
Mar 22, 2009 | 1996 Chevrolet Cavalier
Sony STR DE835 center channel issues.
it could be your wire. try using different speaker wire. if it still has that same problem, take the cover off and tap on the amplifier.
Mar 01, 2009 | Sony STR-DE835 Receiver
One speaker channel is crackly.
There is Definately a Short in the Amp if tapping Fixes it. Could try opening the amp and Inspecting the Back side of the Terminals. You can use a Voltometer and check the Wiring inside. Turn off Power Before doing this!
Jan 01, 2009 | Marantz Audio Players & Recorders
X205-SLi1 Speaker Problem: The left speaker is stuck in a constant thumping/tapping noise machine-gun noise pattern. You can actually see the left speaker go up and down repeatedly as it makes its tapping...
sounds a lot like you have a speaker that's crying for removal and replacement..you could try to use the volume slider, with the left/right balance, and see if it's generic to the system, or just one particular application. sounds like it's happening all the time your computer is on
Mar 20, 2008 | Toshiba Satellite X205 Notebook
Stuck!
I was able to fix this issue by opening up the receiver, removing the circuit board that the power button and speaker selector knob contact, and then reseating that board back onto the circuit board it was connected to (the one with the majority of the control buttons).  This completely resolved the problem.  The power button works again and the audio does not drop out anymore.
Aug 18, 2007 | Sony STR-DE945 Receiver
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
78 people viewed this question
 Grubhead
Grubhead
