Question about HTC Vivid
My htc vivid keeps crashing and reboots already have performed factory reset a few times still n/g
    Problem Solver:
  • 7 Answers
Try custom ROM from XDA forums. Google for it. Laos, be sure your phone is not under warranty. You cannot claim warranty for it later. This should definitely work.
Posted on Oct 24, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is... hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S. Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure. Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
Posted on Feb 03, 2010
mobil master
  • 14641 Answers
SOURCE: how do you factory reset HTC Vivid?
Dear:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 16, 2012
How do u reboot the htc one
If there's a problem with your screen or you're otherwise unable to do a factory reset via the settings menu, then you can use the hardware buttons to do a reset too. Simply turn your HTC One off, then press and hold the Volume Down and Power buttons. Continue to hold them until you enter the H Boot screen.Aug 23, 2014
How to hard reset the HTC One - AndroidPIT
https://www.androidpit.com/hard-reset-htc-one Feedback About this result
HTC One (Verizon Wireless) - Restarting HTC One (Soft reset ...
www.htc.com/us/support/htc-one-verizon-wireless/howto/394150.html
  1. Cached
  2. Similar
Restarting HTC One (Soft reset) If HTC One is running slower than normal, is unresponsive, or has an app that is not performing properly, try rebooting and see if that helps solve the problem. If the display is off, press the POWER button to turn it back on. Press and hold the POWER button, and then tap Restart.
HTC One - Resetting HTC One (Hard reset) - SETTINGS & SERVICES ...
www.htc.com/us/support/htc-one/howto/365649.html
  1. Cached
  2. Similar
Performing a factory reset from settings. Go to Settings, and then tap Backup & reset. Tap Reset phone. Tap OK.
How do reboot the htc one Google Search
Nov 08, 2016 | HTC Cell Phones
I forgot security code to my HTC rezound beats audio phone
  1. From the Home screen, press MENU , and then tap Settings.
  2. Tap Storage > Factory data reset.
  3. Tap Reset phone, and then tap Erase everything.
Performing a factory reset using hardware buttons
If you can't turn HTC Rezound with Beats Audio on or access settings, you can still perform a factory reset by using the hardware buttons on HTC Rezound with Beats Audio.
  1. Remove the battery, wait for a few seconds, then reinsert the battery.
  2. Press and hold the VOLUME DOWN button, and then press and hold the POWER/LOCK button.
  3. Wait for the screen with the three Android images to appear, and then release the POWER/LOCK and VOLUME DOWN buttons.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER/LOCK button.
Resetting HTC Rezound with Beats Audio
Apr 03, 2015 | HTC Cell Phones
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
How to reset htc chacha cell when it is demanding email &p/w rejecting
Performing a factory reset using hardware buttons If you can't turn HTC ChaCha on or access settings, you can still perform a factory reset by using the hardware buttons on HTC ChaCha.
  2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Mar 24, 2014 | HTC Chacha Smartphone
How do I perform a factory reset on Nabi Jr. Daughter uncertain her info on it??
A factory reset will wipe all data including installed apps. Make sure the battery is fully charged before beginning this as you could "brick" your Nabi. Here's the video I used with the procedure on it: https://www.youtube.com/watch?v=T-bamfAKvgk
Steps are:
  1. turn it off
  2. hold power and vol + button until menu appears
  3. press vol - to highlight "recovery kernel"
  4. press vol + to select it
  5. press vol - and vol + at the same time
  6. menu will appear use vol - to select "wipe data factory reset"
  7. press power button to select it
  8. press vol - to select "yes delete all user data"
  9. press power button to select it
  10. this will perform a few actions and take you back to the menu from step 6 should already be on "reboot system now"
  11. press power button to select "reboot system now"
  12. the Nabi will reboot and reset to factory defaults
Dec 26, 2013 | Computers & Internet
How to restore HTC One V T320e smartphone
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
1. Slide the Notifications panel open, and then tap Settings.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
My keyboard on my htc vivid phone wont come up
Go to setting then go to storage then go factory data reset.... then your keyboard will come back on your htc vivid phone will come back cause i just did it
Aug 07, 2012 | HTC Vivid
My phone is automatically switch off
Talking on the phone with a bluetooth headset and self-rebooted.
Playing abduction and crashed. Self-reboot constantly at the X screen
Took battery out for 15 second, and tried again, same thing.
Did it a second time to fix it.
- reading google.com/reader and crashed. Self-reboot constantly at the X screen
Did a factory reset to see if it helps.
During market downloads of apps, crashed again and rebooted
Phone used edge more than 3g lately in the past few days.
After factory reset, using 3g again.
Had the phone for 3 weeks, so the tech support guy said I can only get it repaired or replaced by a refurb unit...Sounds like a bad deal to me...
and to make it even worst, I bought the google dev g1 a few months ago before this...$1k down the drain...
Feb 14, 2012 | Cell Phones
Every so often my thunderbolt will crash and reboot for no apparent reason. Is this normal or a malfunction with the phone
There are a lot of software issues with some applications that lock up the phone.
Try deleting newly downloaded applications and work backwards until your phone does not reboot again. Any paid for apps can simply be re-downloaded through the Android Market.
If this does not work, attempting a factory reset will be your next step.
Factory Reset
1) Make sure you back up all of your contacts, pictures, etc. Factory Resetting could possibly delete all data off of your microSD card, and you wouldn't want to lose any of it.
2) Once done, from the home screen tap the Menu key.
3) Tap the Settings Option.
4) Under Settings, tap Privacy
5) Select Factory Data Reset
6) Tap Reset Phone.
Once done, your phone should be restored to factory defaults.
If for some reason your phone has decided to continue crashing and rebooting, you must perform a Hard Reset. This will undoubtedly remove contact information.
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
Remember, everything will be lost from this point on; so be sure you have EVERYTHING backed up that you do not wish to disappear. This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
Open Questions:
See all HTC Vivid Questions
HTC Vivid Logo
55 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
