Question about Bulldog Security Vehicle Parts & Accessories
I have a bulldog remote start. It worked great for a year but now it will not start my car. It turns the engine over but is a very short crank. Also it makes 3 clicking noises from the box inside the car.
  • 777 Answers
I would say get the schematics from bulldog and trace the lines, it sounds like either the wiring is bad or one of the relays is bad.
Posted on Oct 24, 2013
emo-of-death
  • 9 Answers
SOURCE: remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Posted on Jan 06, 2009
  • 27 Answers
SOURCE: No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Posted on Jan 10, 2009
  • 1596 Answers
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
Posted on Feb 12, 2009
albaby6
  • 58 Answers
SOURCE: car won't start, makes clicking sound
If you have a bulldog remote start, you should have it removed right away. I work at best buy, and we will not install these any more because of the problems they cause. You should buy something made by DEI, they cost a little more, but are very well made and come with a lifetime warrenty.
Posted on Aug 18, 2009
MECP Guy
  • 344 Answers
SOURCE: I have a bulldog fcc id:h50tr13 ic:1640b-tr04
if it's the lcd screen, it can be fixed for $25 us
Posted on Feb 22, 2010
How do i get my bulldog seurity rs82b to crank longer
If you are using the "tachless" start option and the unit will not crank long enough to start the vehicle, you might want to opt for using the tach wire set up. When selected, and following the Tach set up, the unit will then crank until the engine is producing the preset RPM programmed into the unit's memory.
My experience with the RS82 is favorable, but every now and then, the tach wire must be used to be more reliable, especially on some older model vehicles. I have no knowledge of being able to add crank time such as DEI units are capable of.
Dec 16, 2014 | Bulldog Vehicle Parts & Accessories
Have model #RS82 installed it on a 2001 Dodge Dakota(no alarms or power windows, did not connect red&black#2,blackwhite#3, &black white #3 wire from the 9 pin harness. After making all connections...
Did you install the hood pin switch? If so, does the blower and dash lights come on when you press the start button on your remote? I have one installed on my 2005 and it works great. I did not install the hood pin switch ( Not the best idea if you take the vehicle to a mechanic for engine repair.) But I shorted the wire as if the hood were closed all the time.
Nov 28, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Does everything but will not start car
what is the make year and model, you may have a transponder key and will require a bypass module
Jan 16, 2010 | Bulldog Remote Starter & T-Harness Kit for...
I have a 2006 ford explorer i put a bulldog remote stater on it but cant get it to start ever thing comes on but the starter wont come on no crank
put the key in the ignition DON'T turn the key, now remote start the car, if it starts, you need a bypass modual, send me a message if you need one and I will let you now where to get the best price where you live
Dec 19, 2009 | Bulldog Remote Starter & T-Harness Kit for...
I have a 01 Jimmy with a bulldog remote starter that when it was installed worked ok. Now its 2 years later and it tries to start but will not fire. Cranks over just a couple of times then kick out.
there should be a way in the settings of the brain that lets you pick a longer cranking time. idk exactly how to do it but if you look in the manual that came with it or go on the web site or call the company they should be able to help you
Nov 30, 2009 | Remote Starter with Keyless Entry
Bulldog remote start
Its a Fault in the Moduel and The Tech support Dont know How to Repair it I Installed a Bulldog Remote start/lock/tail gate on a 02 Blazer and 1 Year later it did the same thing, I just Disarmed it and forgot about it the Owner tried to get help from them to NO Avail.
Jan 20, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Guy
Jan 09, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Started the car with remote. it ran for a few minutes and then shut down. now nothing seems to work cant start or drive with key
disconnect wires from unit then check all fuses. get car to start with key. then let me nkow year/make/model of car and what bulldog unit you have
Dec 07, 2008 | Remote Starter with Keyless Entry
Vehicle Parts & Accessories Logo
106 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
