Question about Cressi Leonardo Wrist Diving Computer
My Cressi Leonardo is almost 1yr. new. it will not change modes. worked fine in my dives but not able to retrieve info from it nor link it to my PC now. What could it be? I thought it might be a low battery.
Battery replace for Citizen Cyber Aqualand NX
My Cyber was working fine and reporting a full charge, but when diving, it would stop working and go into safe mode. I sent it in to Citizen and they replaced the cell, now all is good again.
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
My aprilia leonardo 125 1999 model the oil light wont come on when i turn the ignition to on . but when the bike has be running for 10minutes it works fine. but when the engine is cold it dont can...
i suspect that there is thick gunge in the oil pressure switch which when warm thins down enough to allow the pressure to operate the switch, do an oil and filter change and change the oil pressure switch.
Sep 04, 2011 | 2006 Aprilia Leonardo 125
My 8 year olddell desktop wont come out of standby mode. Even when switched off then turned on again the light flashes like in standby mode. Tried changing cr2032 battery on motherboard as advised by...
Hi elaineblackb ,
Try to do a power cycle and see if that will work.
  1. Turn off your computer and unplug it from the power outlet
  2. While unplug, press and hold the power button for 15 secs.
  3. Try to turn it back on.
Keith
Jun 13, 2011 | Computers & Internet
Bought a archimedes 2 secondhand.any idea where i can get a manual?
Hey lehanfourie
try http://cressi.it/easyNews/NewsLeggi.asp?IDnews=17
or http://cressi.it/easyUp/file/instructions/IB_ArchimedeII_2008_en.pdf
cheers
Feb 27, 2011 | Cressi-Sub Cressi Archimede II Wrist...
I have packed my computer in my backpack and after a few hours now i picked it up and found that it's in the dive mode: top line normally shows no-deco time = so now it's showing 9:59 (like in the...
All dive computers will automatically come off dive mode when they are out of water. sounds like you may have water in it. I strongly recommend that you do not dive with this unit but send/take back to the place where you got it. I would guess it is still under warranty. Hope that helps
Oct 19, 2010 | Tusa Zen Wrist Dive Computer (IQ900)...
Battery is not charging properly ....?
Have you checked the bios battery status and bios version? first check if battery has charge if yes then update the bios. also try to remove batt and use ac adapter alone and check if laptop has sufficient power. try connecting ac adapter to a diff wall socket. if laptop works fine with ac adapter alone then batt might has problem.
Sep 28, 2009 | Dell Latitude D620 Notebook
HOW MUCH WEIGHT WILL CRESSI SUB FLEX BCD INTERNAL POCKETS HOLD??
I have integrated weight pockets, and i am also a cold water dry suit diver (IE: much more weight is needed) and i have never had a problem with the integrated weight pockets not being able to handle the weight. (now they person you talked to at the company was right, most trim pockets cant handle more then 4 pounds.) you may want to give Dive Rite (Trek Wings) a try... that is what i have and i will never buy another BCD... Trek Wings by Dive Rite give you more maneuverability and is trusted by tech, wreck, and cave divers. i also prefer them as a instructor... I have seen Cressi BCD's in action before, but i have never really been impressed.
Jun 15, 2009 | RTO Cressi-Sub Cressi Sub Flex BCD SCUBA...
Cyclic redundancy error when i just copy files to my pen dive. Can anybody solve the problem?there no problem with files or hard disk!!
Hi there.
Cycle redundancy error means that it cannot copy to the flash drive, try formatting the drive first and then copy to it.
Please let me know if you need anymore advice.
Good luck and thanks for using FixYa!!
Jun 04, 2009 | E-Machines eMachines Desktop PC
Cressi Leonardo Wrist Diving Computer Logo
87 people viewed this question
Top Cressi Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Cressi Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
