Question about Symphonic ST427FF TV
Trying to set up dvd player - Symphonic ST427FF TV
    Problem Solver:
  • 17 Answers
Standard CRT TV
Posted on Oct 23, 2013
DVD model #mwd7006 sound but no picture
  • To reset the DVD player unplug the DVD player for 10 seconds.
  • Confirm that the TV has been set to the corresponding video connection of the DVD player.
  • DVD player has three video outputs.Video, S-video and RGB-component.
  • If current connection to TV is not working and the TV has an alternative video consistent with the DVD player try the second.
  • Try DVD player on another TV
Nov 24, 2015 | Televison & Video
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
DVD player loads then stops and says no disc, havent used it in about 4 years ,how do i get it to play dvd, tried to set up like it says but must be doing something wrong
Tries to play more than one DVD disc.Tries to play many DVD disc should be original DVD disc ok no DVD+R copying disc ok.If ur are still getting signal just saying loading signal awhile than say no disc show up, and u did playing it with many dvd original disc.Than the DVD player laser eye reader could be ditry.Tries websites like Amazon.com,Ebay.com to buy a DVD disc set that said like DVD players lasers eyes cleaners.Used it as directions said,if u still getting the same result mean ur DVD player laser eye reader it is dead,not worth repairing the DVD player if the DVD player laser eye reader it it dead,because the laser eye reader it is 90% important to the DVD player unit and the cost of it by replacing it will cost the same as a new DVD player unit.
Aug 29, 2011 | Polaroid 7'' Portable DVD Player
Dvd player causes the tv screen to roll when trying to play a dvd. tv works finf when the player is off
Have you ensured that the dvd player settings are set to pal and that if the disc in use is an ntsc disc that the dvd is set to ouput pal60 or pseudo pal
Dec 29, 2009 | Insignia Televison & Video
Region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
My phillips dvd player (model DVP5990) is not reading disc at all no matter the format. any ideas?
This could be several problems. You should first try to clean the laser head with a cleaning disc. If this does not work you can try resetting the dvd player to the factory settings. This function is found in the settings section under preferences. Use you remote control to open the settings menu and use the up and down arrows to highlight the preferences section. Press ok to enter the sub-menu. Use the up and down arrows to highlight the default setting.Press ok. You have now reset the dvd player to the factory settings. Press the menu button again to escape the menu. All this information is in the owners manual on page (47). Try a dvd to see if the dvd player is working properly. If not you may have other problems that will require you to open the dvd player up to find the problem. These problems could be a laser lens that is not functioning properly or a problem with the transport that is use to set the dvd up for reading by the laser lens. For these problems it is best to have a qualified technician to troubleshoot the problem.You can call phillips customer support at this telephone number 1-800-744-5477. Tell them the model number of your dvd player and the problem you are having with disc player not reading discs. They will be able to help you get service for the dvd player.I hope this information helps you with your problem.
Apr 12, 2009 | Philips DVP5990 DVD Player
Dvd picture
Make sure component cables match colors between Television and DVD player. It should be TV input to DVD output. Try to play at least two DVDs to make sure its not a single DVD that may be having an issue. Also, adjust your television's picture setting to make sure its set to normal. Also access your DVD players menu to make sure the setting are set to normal as well.If it doesn't correct the problem, use a different component input on your television. If problem persists, you may need to contact the DVD player manufacturer to see if its still under warranty and not defective. Good Luck.
Oct 18, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
DVD PLAYER
ok reset factory setting try to burn dvd if problem occer then u need to call a good technision
Jul 12, 2008 | Televison & Video
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Symphonic ST427FF TV Logo
22 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
