Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when I attempt to close the door from the wall switch, the door begins to close but only goes about 6 inches and stops and the light on the motor starts flashing. I checked the sensors located near the floor at either side of the opening. One sensor light is green, the other sensor light is yellow. nothing is in the way, though the door stops as though there is an obstruction. Any advice would be greatly appreciated. Thanks!
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 23 Answers
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Posted on Oct 25, 2013
4 Suggested Answers
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: Liftmaster 1/2 - Will not close
What usually happens is a sensor gets bumped so that they no longer are pointed at one another. They must be for the light on the second sensor to come on. Tweak them and see if you can get the light to come on. If you can't you either have bad wiring going to that sensor or the sensor itself has quit working.
Posted on Jun 15, 2009
  • 31 Answers
SOURCE: liftmaster 41A5389 won't shut
it has to be aligned with its mating optical sensor on the other side of the door. try adjusting it until you get a green light.
Posted on Aug 23, 2009
How to keep the garage door lighe on for less time
The liftmaster garage door openers manufactured after 1984 are set through the logic board from the factory with a setting of 4 1/2 minutes, That setting cannot be changed manually but you can by a premium wall control console that lets you override the logic board settings by simply pressing the light function button that allows you to shut the lights off earlier by simply pressing the button or also you can keep the lights on indefinitely by pressing the button twice! The lights will automatically go back into the 4 1/2 minute mode once the door is operated in either the up or down motion. Hope this answers your question! P.S. The premium console comes with a safety vacation lock also and can be purchased through Ebay or through Liftmaster....Remember the Liftmaster name also make the chamberlain brand and the Sears Craftman openers ...They are all cross compatible on the Premium wall console and have 2 wires on them to hook up (low voltage ) so don't worry you won,t get a shock! Just match the red wire to the terminal marked red and the white wire to the terminal marked white and screw onto your wall! Good luck .Glenn
Jun 05, 2014 | liftmaster Garage Door 1/2 Hp
Door wont close
Roger, does lights blink when attempting to close door?? If so it is the photo sensing eyes. Be sure they are not blocked and properly lined.
If all is ok, replace the photo sensors. Hope this helps
Oct 05, 2012 | liftmaster Garage Door 1/2 Hp
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster 1/2 H.P. opens but cannot be closed (without depressing the button on the wall until the garage door comes down all the way. Any help will be much appreciated
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jan 25, 2010 | liftmaster Chamberlain Garage Door Opener...
Door will not open or close with remote
What does a normal remote do with the lights?
Is yellow and green normal?
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
317 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
