Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Kenmore 106.4126 frig lights out - Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Kenmore Coldspot 106 Refrigerator
It's 12 years old it's gone ,they don't last forever ! Compressor !
Aug 18, 2015 | Refrigerators
Kenmore Elite Refrigerator 596.76253701 Looking inside the frig, I am unable to find the cubic feet fo this frig. Do you know what it is???
Should be a sticker on the back of the unit, most times they only state make and model number. You may have to enquire from Kenmore for cubic feet if it is not stated on the sticker.
May 27, 2015 | Kenmore Refrigerators
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Frig stopped cooling, unplugged & replugging worked - now what?
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Apr 10, 2009 | Kenmore Refrigerators
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My Kenmore Refrigerator will not dispense water'
Hi!! you have a bad water valve located in the lower back of the frig..or your water tank located inside your frig is frozen.goog luck..
Jan 20, 2009 | Kenmore Refrigerators
Kenmore side by side frig
hi!!! it looks like you have a problem with the damper control mechanism inside your frig section..most all new model have an electronic board.replace that and you should be fine..good luck..
Jan 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
May 26, 2008 | Kenmore Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
