Question about iHome IH-M360C Mouse
I home usb mouse not working - iHome IH-M360C Mouse
Are Mortgage Loans cheaper than a Home Loans?
Wireless Mouse, AmanStino ML11 2.4G Cordless Mouse with USB Nano Receiver
  • Adopt the 2.4G Wireless Technology up to 10M reception, for a powerful reliable connection;
  • ( Receiver is stored in the mouse; please open the battery cover to retrieve it)
  • Ergonomic design, optimized wireless solution for a smooth, precise, easy and affordable mouse;
  • Auto Power Off (APO) for more energy saving: the mouse will be switched off automatically when the receiver is disconnected, the PC is switched off or the mouse is set aside;
  • Optimized 1200DPI high definition for an enhanced and best performance, just like navigating with your wired mouse;
  • Pair-free technology for plug and go ready; works with Windows 2000, XP, Vista, 7 8, 10
Wireless Mouse AmanStino ML11 2 4G Cordless Mouse with USB Nano Receiver...
Nov 21, 2016 | Computers & Internet
My mouse does not work. I originally could not turn the pc on for approximately 1 week. I took it in for repair , they could not find the problem. When I returned home and repluged all the wires the...
Are you using an USB mouse? If so you may like to try another USB port or there might be some wire to the USB port not plugged right. You can check the printing on the motherboard to see how it should be plugged. (There is several wires for each USB port with a certain order into an plug on the motherboard when the USB port is not on the motherboard). You can check the power and make sure it is connected well and enough for everything. Other options will be to use other mouse like wireless mouse or PS/2 to USB converter to make a PS/2 mouse an USB mouse or vice versa. Checking motherboard and measuring every voltage could be very complicated.
Jul 24, 2010 | HP Pavilion dv1600 Keyboard - 412374-001
My mouse wont work on my home PC all of a sudden
Some Computers take longer than others to recognize that there is a
mouse plugged into the computer. If it is a USB mouse try plugging it into a different port or, if a disc came with the mouse, run the disc and install it manually. If all that fails consult a experienced HP consultant. Hope this helps and please don't forget to rate.
Feb 23, 2010 | HP Computers & Internet
My wireless mouse will not work, I forget how to 're'-pair it. It was functioning normally before i left home for a couple of days. Both the mouse and the other part (that goes into the usb port) are...
1. Try unplugging usb device and replugging in (I'm sure you already did that) LOL
2. Uninstall device driver
3. After uninstall plug in USB device
see if that works
Nov 14, 2009 | BenQ M310 Wireless Mini Optical Mouse
Keyboard and mouse not working
what sort of keyboard and mouse is that.. if its a serial or ps/2 then get the ps/2 to usb cable and try it using your usb port. if its usb mouse and keyboard then the better way is to get 4 usb hub and use it with hub.
hope it will solve your problem.
cheers
Apr 27, 2009 | Computers & Internet
Activating COT2 wireless mouse
Your ACME COT2 wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your Toshiba Satellite and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Computers & Internet
Cannot connect mouse to the usb port
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 18, 2008 | Computers & Internet
USB mouse...(Razor)
I would check to see if, in your bios settings, that Legacy USB mouse detection is enabled.. That is usually a cause for this problem if it is not enabled....
Also, make sure the drivers you are using are for the right Operating System (ie, Vista, XP Home, XP Pro, etc...)...
Apr 09, 2008 | Razer DeathAdder RZ01-00150100-R2M1
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
iHome IH-M360C Mouse Logo
Top iHome Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Tom Chichester
Are you an iHome Computer and Internet Expert? Answer questions, earn points and help others
