Question about Compaq PRESARIO CQ62Z-200 CTO LAPTOP LCD SCREEN 15.6" WXGA HD GLOSSY LED (SUBSTITUTE PART NO.) (22099288909)
Cq62z-200 black screen no picture video gone - Compaq PRESARIO CQ62Z-200 CTO LAPTOP LCD SCREEN 15.6" WXGA HD GLOSSY LED (SUBSTITUTE PART NO.) (22099288909)
    Top Expert:
  • Compaq Master
  • 22,714 Answers
If you plug the VGA output into an external screen, that will tell you where your issue is.
Posted on Oct 22, 2013
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
Black screen
image sensor gone bad... buy a new one...
Feb 16, 2010 | Canon ZR60 Mini DV Digital Camcorder
Hi, i'm having trouble with my HLN 5065w samsung. The color on the screen starts out normal, then flickers to neon purple and green. then the screen goes black completely and I have to unplug it. Do you...
Your Convergence has gone out and very likely needs work, this is the most common problem inthese big screens.
You may not be able to realign that picture without some new parts unfortunately.
There are some circuits that align the RED, GREEN, and, BLUE, picture tubes to make the picture you see.
The components that do that job are called "convergence" circuitry. The usual components to fail are the "Convergence Amplifiers" which are usual a pair of Integrated Circuits mounted to a large heat sink.
the repair cost is between 200 to 400 usd.
Post further comments if you need more help or information...
Good Luck!!
Thanks
Oct 16, 2009 | Samsung HLN5065W 50" Rear Projection...
On my laptop the screen picture has gotten smaller and the outside of it is black. i dont know what the problem is. it is an old laptop and i dont no whether its from age.
Its not actually a problem or a fault, its just a setting that has been changed in the video card settings.
There are two ways to fix it.
One of them is to adjust the resolution, right click on your desktop and select properties, from there select the last tab which says settings, see the resolution slider, slide it towards the higher end, where the numbers get bigger, and apply, if the problem got worse you have gone to the wrong direction, if the black area is smaller or gone you have gone to the right direction. adjust the resolution until you don't have black outside on the display.
if the text and icons become too small, you need to open the advanced settings from the page, and find monitor scaling settings so that the computer fills the whole screen regardless of the resolution in use.
After you have found the scaleing setting you can go back to the resolution slider and slide it down untill you can read the screen well, the picture should cover the whole screen.
Sep 06, 2009 | Compaq Evo N610C Notebook
My stored data has disappeared
J'aimerais avoir le livret d'instructions pour la dactylo de marque Smith Corola XE 5200
Mar 26, 2008 | Smith Corona Wordsmith 200 Typewriter
AKAI Black TV screen, but still have audio
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Mar 10, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Compaq PRESARIO CQ62Z-200 CTO LAPTOP LCD SCREEN 15.6" WXGA HD GLOSSY LED (SUBSTITUTE PART NO.) (22099288909) Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
