Question about LG 24 in. LDF 7811 Built-in Dishwasher
LG Dish washer model LD1204M1, during cycle OE. Looked in manual and said it can be , filter clogged, drain hose kinked or blocked or the drain pump/motor or circuit is troubled! I have checked and cleaned all filters, checked all hoses. Also checked the pump taking water away, but cant find the issue. I have been told it could be the PCB ASSY, but don't know how to check that or what to do next. really can't afford to go buy a new dishwasher, so any help would be really appreciated! Kindest regards, Roger.
  • 155 Answers
PHYSICALLY CHECK PCB FOR OVERHEATED CONNECTION USUALLY BLACK MARKS OR BULGING PLASTIC.
Posted on Nov 03, 2013
4 Suggested Answers
SOURCE: OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Posted on Jul 11, 2008
  • 423 Answers
SOURCE: LG LDF6810ST dishwasher
Steps to fix OE are as follows:
-Check the Drain Hose is not kinked or blocked.
-Are all wiring connections OK?
-The drain outlet of sump is blocked.
-The Drain Pump/Motor or circuit has failed.
To check the pump motor: -Measure the electric resistance of Drain Motor. (best between 20-40 ohms) If out of range, replace the Drain Motor or repair the Circuit.
Good Luck! Please report back your findings.
Posted on Mar 30, 2009
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Posted on May 06, 2009
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Help!! the washing machine wont spin out it keeps commin up wiv oe?? plz help
OE means that the drain filter or hose is blocked or kinked or clogged.
Clean and straighten the hose and clean filter.
Good luck
Feb 08, 2010 | LG WD-16115FD Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
LG 24 in. LDF 7811 Built-in Dishwasher Logo
75 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
