Question about LG Kitchen Ranges
Circulating fan quit working. fuse or replace is the question??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
I would try the fuse first
Posted on Oct 22, 2013
I had the radiator to my saturn replaced bacause it was cracked. Now when the engine is turned on, the fan works, then stops. Can someone help?
you will need to change your relay most likely in your fuse box ,,put some glasses on to see the fuse diagram to find your relay ...change it ,,,it is wearing out and causing your fan to kick off and on
Oct 22, 2013 | Cars & Trucks
I turn off the car and remove the keys and the bottom rear fan runs.
If you are refering to the cooling fan this is quite normal as when the coolant stops circulating it heats up and turns on the cooling fan. only goes for a while then stops
Nov 27, 2012 | 2007 Mazda CX-9
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
Blower fan starts fine sometimes circulating fan starts right away then after about 4 0r 5 min the small 3 amp fuse blows and shuts down whole unit. What is this fuse for and why does circulating fan...
Hi WFO9, It sounds as though the fan capacitor is under specs. It is probably losing its capacitance ability, they are usually rated plus or minus 5% of the value printed on the case. If however the capacitor is no longer within the rated specs. the fan motor will draw too much current and will then blow the fuse. either that or after the normal start delay built into the Ac, which is 3-4 minutes, the compressor tries to start and again draws to much current and blows the fuse. have all the capacitors checked and replaced if they dont meet the specs printed on the capacitor case. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
The fridge section is warm, the freezer is OK
sounds like the circulating fan is wearing out. This fan supplies circulation for the freezer as well as the refrigerator when the motor for this fan starts to wear out the circulation supplied is reduced to a point that the freezer will work but not the refrigerator because the fan does nnot run fast enough to circulate the air thru the refrigerator. The minimum cost to repair/replace this fan assemble is around $300.00
Jul 11, 2009 | Refrigerators
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
Kitchen Ranges Logo
55 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
