Question about Miele Touchtronic W1113 Washing Machine
Miele w 1113 doesn't spin all the water out on a full load. It works fine on a half load. What should I try?
2 Suggested Answers
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
t spins, but doesn't pump
see line clogged and fix it.
It doesn't spin or pump
frozen pulley
It pumps, but the water returns
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
The washer is having the following issues. Overfills excess water drains out on the floor down the overfill pipe. Washer cycles and doesn't spin.
The float on the water level shut off valve is probally stuck and not telling the washer that its full and to turn off the water. once thats fixed it will probally cycle normally. Try it on half load and see if the water stops at the correct spot.
May 15, 2011 | Washing Machines
Dishwasher leaves white film on plastic dishes and stainless steel . Salt is full and rinse aid is full.
If your dishes or plastic dishes appear with a white filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Miele Dishwashers
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Miele Touchtronic W1113 Washing Machine Logo
57 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
