Question about Jenn-Air Ovens
Prg3610LP convection oven fan very noisy, just started. no previous problems
  • 87 Answers
SOURCE: convection fan not working
Check for a bad fan motor or a jammed blade.
Posted on Jun 14, 2007
  • 537 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
f the oven doesn't heat and the on-off light works, test the appliance controls, motor,
and heating element .
Posted on Nov 15, 2007
barkencoa
  • 3463 Answers
SOURCE: Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Posted on Dec 17, 2008
bigg t
  • 640 Answers
SOURCE: Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Posted on Apr 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Posted on Jul 27, 2009
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
What wrong when a jenn air convection over fan make noise
What kind of noise? Has the type of noise it's making different now then previously?
Nov 19, 2013 | Jenn-Air Ovens
Kitchen wall oven there is a buzzing sound when in the convection bake cycle
You don't tell the age of the oven... but the convection fan motor bearing is stressed by the heat of the oven.... and over time can cause all sorts of noises.
You may want to place a small amount of WD-40 on the convection fan motor bearing... just to confirm it as the problem/
Best to replace the motor if it is the problem..
-Jim
Oct 17, 2009 | Ovens
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
E32MS Convection Oven not heating properly fan working intermittently
Replace thermostat. Service Engineer best but if you are competent then you could replace yourself.
Sep 19, 2017 | Moffat E32 Full Size Electric Convection...
Oven is noisy
next itme you get an authorized co. to come look at it ask them to call the "techline", f&p has an excellent tech resource hotline for us tech ive never called and had them not at least lead me in right direction.
Feb 27, 2008 | Fisher and Paykel AeroTech OS302 Electric...
Convection fan not working
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
20 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
