Question about Electric Eyeware Kid Trax Red Fire Engine Electric Ride On
Decals for fire truck - Electric Eyeware Kid Trax Red Fire Engine Electric Ride On
How do I find the VIN number, the decal is on the fire wall can not read engine block number is A28019B
Hi Don:
Vin number should be on dash in front of steering wheel. read from outside. Sould also be on tag on drivers door jamb, and on registration papers.
Dec 03, 2015 | Cars & Trucks
Decals for controls
No need to purchase the overlay - www.stovedecals.com can provide you with replacement stove decals for this model. The decals are made in the USA, Stove Decals is USA's leader in replacement stove decals!
Jan 25, 2014 | GE JS905SKSS Stainless Steel Electric...
I was told fuel pump was out but can hear it run i put gas right into the throttle body stil will not start has fire on all cyl its the timeing right
Here's the guide to the timing chain.The Ignition Timing
Computer operated - electronically controlled (refer to decal)
Dec 30, 2012 | 1999 Pontiac Sunfire
I cant remember the order of my ignition leads
You do not give a year, model, or size engine, but I still may be able to help.
Look at the underside of the hood and also look around the radiator mount. You should find an emissions decal. It contains information such as firing order, timing, and spark plug type and gap.
Feb 19, 2011 | Mitsubishi Montero Cars & Trucks
What coil fires on what cylinder on a 2002 ford taurus 3.0 liter
coil pack should have numbers on it check follow the leads firing order should be under bonnet decal trace them back to the coil pack and number them
Jun 06, 2010 | 2002 Ford Taurus
I have vacuum leaks .I have problems connecting the vacuum lines
you need to find your decal on the underside of hood or on the shield above the radiator cooling fan.
1997 PCED OBDII-A SECTION 1A: Description and Operation
Vehicle Emission Control Information Decal Each vehicle has a decal (Figures 1 and 2) containing emission control information that applies specifically to the vehicle and engine. The specifications on the decal are critical to servicing emissions systems.
typical decal
Figure 1: Typical Vehicle Emission Control Information Decal for 49 States Vehicles
Figure 2: Typical Vehicle Emission Control Information Decal for California Vehicles
Figure 3: Typical Vehicle Emission Control Information Decal for Canadian Vehicles. In addition to the tune-up specifications and procedures, the emission decal shows a color-coded (shown in black and white) schematic of the engine vacuum system. The color coding on the schematic represents the actual color coding on the vacuum hoses. However, there will be instances when a hose color does not match the color on the decal.
Decal Location Typical location of the decal will be on the underside of the hood or the radiator support sight shield.
Apr 04, 2009 | 1997 Ford Windstar
Electric Eyeware Kid Trax Red Fire Engine Electric Ride On Logo
180 people viewed this question
Top Electric Eyeware Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
