Question about Denon AVR-1909 Receiver
Denon avr-1909 has sound but no video, tried everything!!
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Denon requires that you assign video to specific ports. HDMI, RCA or any other- you have to select which type and which port and you will get video.
Posted on Oct 24, 2013
  • 33 Answers
SOURCE: Lost audio for no apparent reason
Try unplugging your HDMI cable from the AVR I would like to see if your AVR is trying to use HDMI out instead of the composite. Next try plugging each device directly into your television, this will isolate the issue and tell us for sure whether or not it's the AVR.
Posted on Jul 10, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
petraman7
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Posted on Mar 09, 2010
I have no audio on any component, how do I fix problem
It could be build up of dust on the headphone socket which is disconnecting the audio to the amplifier circuits. Try to blow air into the socket at high pressure to dislodge the dirt inside. This might help.
Look at this post as well.
Home audio video forum Denon Receiver Problem Video but No Sound
Sep 26, 2014 | Denon AVR-1909
My denon receiver keeps switching from H/P input on to H/P input off automatically which turns the sound on and off?
You need to replace the headphone jack. It has bad contacts that make the unit think there are headphones plugged into it. If you do not plan on using headphones, you can take the cover off and unplug the cable that goes to the headphone jack pcb and this should clear up the problem (please disconnect the power cord before trying this).
Aug 22, 2014 | Denon AVR-1909 Receiver
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
I have a denon receiver avr 1909 and the remote control volume button do not work. A new remote control for this receiver is available?
If you mean a replacement, then I would contact Denon they should be able to tell you where and who can supply one. Generally replacement remotes are very expensive. So you might want to consider a universal one.
Aug 04, 2013 | Denon AVR-1909 Receiver
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
I need reset DENON RC-1099 in begin state
Entering a new remote code will automatically erase the existing code for the device it is currently operating.
The remote for Denon devices is 111.
http://www.usa.denon.com/AVR-1909-OM_E_004.pdf
Dec 13, 2009 | Denon AVR-1909 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
No sound playing through microphone
The microphone included with this receiver is for audio adjustments only. That's the "Audyssey Laboratories' MultEQ® six-point auto setup and room calibration system". You cannot hear yourself speaking through the microphone.
Nov 26, 2008 | Denon AVR-1905 Receiver
Nov 05, 2008 | Denon AVR-1905 Receiver
Denon AVR-1909 Receiver Logo
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
