Question about Toys
I have a nissan urvan an it is idling but the check light starts to flash when driving an the van will lose power an will white smoke a lot ,i changed the tps sensor still the same what can my problem be??
  • 2,359 Answers
White smoke from tailpipe is a sign of blown head gasket.
Before invest money on a full head gasket you should check out the video for www.steelseal.com
Posted on Jan 15, 2014
I have a nissan urvan 1988 petrol E24 model..problem is in the morning when cold when driveing it speedo will all of a sudden go from 60km to 80km even 100km
www.botsofprey.org/F/cars/t25797951-nissan_urvan_1988_petrol_e24
I have a nissan urvan 1988 petrol E24 model..problem is in the ... Good luck & keep in touch. , jack the car up and take a bar lift up on tire and ck ... My nissan urvan 2005model ve25 with a 2ltr petrol engine ka20 has difficult starts with a cold ... is displying a fan error when switching on and fan stays at max speed.. any help?
Jul 27, 2015 | Nissan Cars & Trucks
Lots of white smoke and low power
You may have a leaky head gasket. Have a mechanic do a compression test.
Dec 17, 2013 | Peugeot Cars & Trucks
P7 ful/inj tim f/b
Possibly a BLOCKED FUEL FILTER ... I had the same problem with my old Toyota Tarago some time ago. Every time you accelerate to 80kph [50mph] the motor would just DIE.
I could still start AND drive it SLOWLY but as soon as I passed 50mph/80kph it stopped dead.
Engine was STARVING for fuel.
Changed the in-line fuel FILTER ... problem solved.
Nov 18, 2013 | Pronto Rotors 2000 - 2008 Nissan Urvan...
NISSAN CEDRIC 2001, ENGIN STOPS WHEN PRESS BRAKE PEDDEL
There are few possibilities that can cause such problem.
I recommend you few help links related to your problem.Click the link below and follow the troubleshooting;-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Brake pedal stuck? http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
emits whitish bluish smoke and bad fuel smell from exhaust
http://schematicsdiagram.blogspot.com/2011/12/van-emits-whitish-bluish-smoke-and-bad.html
White smoke and Acrid Smell? http://whoisbyme.blogspot.in/2012/07/white-smoke-and-acrid-smell.html
---------- Car stalls and throws white smoke from exhaust? http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
This will help.
Thanks.
Jul 20, 2012 | Cars & Trucks
Started white smoking and losing a little coolant. Not getting in oil. no power lose. no sign of leaking.
if you are losing coolant and and producing white smoke from the tailpipe you have the classic sign of a bown head gasket. usually this smoke is accompanied by a bitter sweet odor. most common causes are severe engine overheating or severe misfire(flashing check engine light). take the car in for a diagnosis.
May 04, 2011 | Ford F-250 Cars & Trucks
New problem, never had this before. Started up today and the 2000 nissan urvan (QD32) 3.2l Desiel made a hiddious knocking sound from the engine, It was jumping, I took key out of ignition and van kept...
your engine is dieseling, keeps running after you turned it off. usually a timing problem, your timing chain/belt just skipped a notch. the noise you heard was probably valves crashing on the pistons. you will need a rebuild or a swap to keep it alive.
Jan 13, 2011 | Nissan Minivan Cars & Trucks
1994 AWD Astro van overheated, then lost ALL power
it seems that the engine blew. the rings, rod bearings, main bearing etc. Sorry but it sounds like that. Especially the smoking at the exhaust. take it back to the one who sold it to you.If possible.
Feb 16, 2009 | 1994 Chevrolet Astro
95 Chevy Blazer 4.3 white smoke at idle
my 1988 chevy blazer 4x4 smokes on cold starts till it warms up then it goes away what is causing it
Jan 11, 2009 | 2007 Mercury Hybrid 4WD Hybrid
Bogs and backfires
What have you done so far? Does your van have electronic ignition or points? If the latter i'd check/replace points, capacitor & white, low tension wire inside distributor. Also check the spark plugs (all four should have the same grey/brown colour) & H.T. lead resistance, especially if the fault occurs under load/acceleration.
Jun 27, 2008 | 1987 Nissan Pickup
Toys Logo
32 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
