Question about Briggs & Stratton Garden
Backfire smoke - Briggs & Stratton Garden
  • 351 Answers
Possibly valves
Posted on Oct 23, 2013
Need help my Busa started to miss backfire a little smoke was only when I changed gears
Gavin, sounds like a bad plug or a coil on its way out.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | 2003 Suzuki GSX 1300 R Hayabusa
Backfire, Black smoke from exhaust, spitting and sputtering
If you have not replaced plugs start there A bad map sensor will also cause black smoke and poor running
Feb 15, 2014 | Dodge Durango Cars & Trucks
Backfire smoke
This could possibly be caused by several things however the most logical and common reason is simply a sheered flywheel key. This will throw the engine out of time allowing it to fire out of sequence when valves are open instead of closed. I hope this helps you and gets you going again.
Oct 01, 2013 | Husqvarna Garden
Changed O2 sensors and white smoke starts pouring out of exhaust
White smoke is usually steam which would indicate a blown head gasket or crack in block. Hope it's something easier.
Jan 15, 2013 | 1999 Ford Taurus
Ford Focus 2005 - cold start backfire - runs great after 5 mins, when hot
White Smoke out the exhaust, is usually a sign
of coolant & most likely the start of a bad head gasket
At this point your use of the car should be curtailed,
to prevent any further damage
You should not use the car at all, until all issues are
diagnosed & resolved
Plan on using other means of transportation
Jun 21, 2012 | 2005 Ford Focus 1.6
Single cylinder yanmar diesel engine on log splitter back fires out of exhuast & blows out black smoke
Engines runs for a couple of seconds then loudly backfires with a flash of flame out of the exhaust followed by a plume of black smoke. Then runs sort of ok for a couple of seconds then repeats the backfire again AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Apr 21, 2012 | Cars & Trucks
1992 toyota camry v6 backfires and has white smoke
It seems you may have a head gasket leak from the coolant jacket to one cylinder or more.
To confirm this you should get a radiator leak-down test, to see if the coolant jacket does have a leak, and a compression test to see if one or more cylinders have a leak.
The white smoke is coolant vapour, and the backfiring, fuel igniting only once it gets to the hot exhaust from other cylinders.
Apr 17, 2012 | 1993 Toyota Camry V6
Backfire problem and bad smell smoke
i would check the timing as this will cause it to backfire
Feb 17, 2012 | 1996 Mazda Familia
Cutting out in first unless have revs up starting to blow smoke lost power in all gears little bit of backfiring
White smoke means blown head gasket. Black smoke means to rich of fuel. Backfire could be timing is out sounds like timing chain or belt is going.
Feb 01, 2011 | Ford Laser Cars & Trucks
Garden Logo
19 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
