Question about MTX Jackhammer JH4512-04 Car Subwoofer
HOW TO WIRE
WHATS THE BEST WAY TO WIRE 2 10-4OHM JACKHAMMERS TO A PIONEER 1600 WATT CLASS D MONO BOCK
    Top Expert:
  • 12,223 Answers
See the diagram attached and proceed according. God bless you
Posted on Oct 23, 2013
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
If i have a 4 channel 2000 watt amp, can i use 1600 watt wires if i only have 2 subs hooked up to it?
Yes, you will be fine. 4 gauge power wire is sufficient for a couple of reasons, the primary one being that most of the companies that are boasting 2000 watts for a 4 channel amp are off brand "web-retail only" companies, and they severely over rate the power output of their amplifiers. Secondly the supposed 2000 watts is peak power and not rms power. Peak power means how much power that amp can put out during absolue climax of the music or during a tone burst. RMS power is how much that amp will put out continously to your speakers or in this case, your subs. If you look at the spec sheet of that amp, in all actuallity you're probably only getting 200-300 watts rms even bridged.
On a side note, if you really want to push your subs hard, you might want to consider getting a mono block or "class d" amplifier and use that 4 channel amp to push your surround speakers. Class d/mono block amps are specifically designed to push subwoofers and will give you the most efficient power out and the best heat dissipation to withstand the output required to drive subwoofers. You'll get better bass and also more adjustability to tweak the sound levels coming out of your subs. Hope that helps.
Apr 02, 2011 | Car Audio & Video
Ihave a gm-d84004m 1200 watt amp whatsize amp wires should i use
if you are talking about the power and groung use atleast 4 gauge for the subs i usually use 10-12 gauge
Jul 10, 2010 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
I have 2 pioneer tsw33c 10 inch subs and a pioneer
get amp kit if u wat high performenc get most exspensive kit as for the sub u could bridge them as for the stereo and speaker just make sure the posi
Mar 15, 2010 | Car Audio & Video
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
800 watt pioneer mono block blue light comes on then goes off
sounds as if u have a short going on somewheres maybe a loose gound wiredo u have the gain set to hi.check all connetions..check sub connections a sub short will put your amp in protect mode
Sep 01, 2009 | Pioneer 800W Class-D Mono Amplifier With...
I have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Jul 12, 2009 | Car Audio & Video
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
I have just brought a GMD8400M PIONEER MONO BLOCK CAN YOU SEND ME THE DIAGRAMES ON HOW TO INSTALL IT.
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/GM-D8400M_OwnersManual1128.pdf
thats the link to the owners manual enjoy.
if you ever want to upgrade to a higher quality amp let me know, for about 300$ i could have gotten you into a 2000 watt RMS mono block class d that is competion grade.
for a 600 watt like what you have i coulda gotten you into it for about 210 - 225
and for the same amp that you bought i coulda done for about 200
pioneer decks are really nice but the amps are only low to middle end grade.
Sep 17, 2008 | Car Audio & Video
MTX Jackhammer JH4512-04 Car Subwoofer Logo
56 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
