Question about DeLonghi DCU72 Coffee Maker
DO NOT STAR TO HEAT THE WATER - DeLonghi DCU72 Coffee Maker
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change ellement .
Posted on Nov 02, 2013
Whirpool dishwasher not drying with heat
The heating element is bad,if it is getting voltage yet has no amp draw it is bad.
Apr 07, 2015 | Whirlpool Whirpool Energy Star Dishwasher...
Put in a second t-stat to run just my blower on my
To avoid all sorts of wiring problems use only one two stage heat thermostat and wire outdoor boiler to first stage of heat or disconnect white wire from original thermostat and run 2 wire thermostat cable (white and blue , Heat and common to control outside water furnace control ) from original furnace to outdoor 24 v furnace relay .
Oct 01, 2014 | Heating & Cooling
Sprayed brake switch on 650 Yamaha v star now lights won't come on till I mash the brakes, What kind of problem am I looking at
Sprayed the brake switch, with what? Water? If so, you can try to use some contact cleaner spray and spray into the switch area and work the switch to help it penetrate. WD40 is also a water displacement item which might help, but it may also require relubrication of the brake lever/perch. You may also check on the perch to see if you can clean and dry the wiring connector that runs from the perch back. A hair dryer or heat gun might help dry it out also.
Oct 15, 2013 | 2003 Yamaha V Star Classic
Bosch Aqua-star tankless water heater had water on gas valve, dried gas valve, I have a spark but will not light
Water in the gas valve is DANGEROUS! The major question is did the water come from a leaking heat exchanger or the product of combustion? If it is from the heat exchanger it may be covered under the warranty (if the installation is proper). If it is from condensate in the flue pipe, it is from an improper installation. If you go to bosch-climate.us you can find a service provider in your area. I service a very large part of NY, some of NJ (Northern) and all of CT.
Sep 05, 2013 | Bosch & Tankless LP Hot Water Heater
Eternal GU-195S Hybrid water heater
Is this new installation? Or old installation that stopped working?
Here's the 100% solution. And it applies to all brands, models, types, of tankless water heater, no matter which error code:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
People should avoid complicated water heaters that claim 'energy star' and '98% efficiency' while proclaiming 'endless hot water' as if the laws of physics, economics and common sense can suddenly be suspended if only the customer would buy expensive, complicated water heater that cannot be maintained or repaired by customer, and there are no qualified technicians who live in your area.
Otherwise you need a service manual, or contact eternal manufacturer. 1-866-946-1096
http://eternalwaterheater.com/pdf/downloads/GU100.pdf
Error E02 does not show in manual.
E2 is ignition failure, which on other brands can be failed PC board... and inadequate incoming air supply, or venting, or failed sensor, dirty combustion parts, air or water in gas line, low gas pressure, wrong gas, etc, or multiples from list above.
May 09, 2013 | Water Heaters
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
Dishwasher cycle never completes
This is a very common complait about dishwashers taking a very long time to complete cycles. More than not if you start your dishwasher cycle wait untill your washer fills with water. Reach in and feel the temp. of the water. If it is cold the dishwasher try's to heat the water. Most of the dishwashers are not design to heat water. And here is the delay. Try to run the water at your sink first until it is hot, Star your dishwasher and see if the cycle runs correctly.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Dishwashers
Is the Whirlpool Electric Water Heater Model # EE3J50RD045V energy star rated
You want to know if this heater has Energy Star label.
I don't know.
Call Whirlpool 1-877-817-6750
Energy Star is a label that means nothing to you.
Manufacturers use energy-star label to promote a product as a money-saver.
They can put an Energy Star label on a giant 10,000 square foot house, and you know that cannot be the truth that a large house saves energy vrs a smaller house.
Energy factor, (energy factor/ not energy star) on the other hand, is a comparison measure how efficient the water heater uses energy to heat a gallon of water, when water heater is absolutely new.
EE3J50RD045V has energy factor of .59, which is completely typical and ordinary for electric water heaters.
The EE3j 50 gallon is an ordinary electric water heater, with ordinary average .59 energy factor rating, so electricity to operate this water heater is same as any other typical 50 gallon electric water heater: it will cost $35-45 a month depending on incoming water temperature, hot water use, thermostatic setting, electricity pricing, and whether you operate heater at peak pricing, etc.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-much-does-it-cost-to-run-water-heater.html
The most important measure of water heater cost does not have anything to do with Energy-star or energy-factor.
The most important measure is total cost of owning and operating the water heater.
So if you spend $100 more to purchase electric water heater with slightly higher energy factor, then it will not pay you back. The difference will be $2 to $4 per year.
All costs are energy.
The total cost of operating water heater includes purchase price, installation cost, cost of repairs, cost of parts, whether you can fix it yourself, expected life of water heater, and replacement cost.
Every water heater has expected lifespan, and will not have resale value except current price of scrap.
Electric water heaters cost more to operate per month than same-size gas water heater.
Gas water heater might cost less over the life of water heater, but gas water heaters are increasingly expensive to repair, and increasingly more complicated, and cost more up-front to buy.
Electric water heaters cost less to buy, are easy to install yourself, are fully repairable by homeowner using generic off-the-shelf parts, and can be made to last many years by keeping tank clean and replacing anode rod every 2 years.
You can make ordinary 6-year electric water heater from box store last almost indefinitely.
Avoid electric water water heater that has electronic controls.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Sep 20, 2011 | Water Heaters
My samsung star is not working because water goes in
Remove the battery, then heat it, put it on a hot place for 20 minute then fixed it back.
Aug 16, 2011 | Cell Phones
DeLonghi DCU72 Coffee Maker Logo
43 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
