Question about Vehicle Parts & Accessories
P1510 trouble code for Daihatsu sirion 2002 - Vehicle Parts & Accessories
  • 118 Answers
Starter Malfunction.
Posted on Oct 23, 2013
2008 Toyota Passo remove glove box
The Daihatsu Boon is a subcompact car/supermini produced by Japanese automaker Daihatsu since 2004, and also sold as the Toyota Passo and the Daihatsu Sirion. The Toyota Passo is sold at Toyota Corolla Store Japanese dealerships. Outside Japan, the first-generation Boon is sold as the second-generation Sirion.
If you can not find Part diagram for Passo then look for Daihatsu Sirion or Boon models.
I’m happy to assist further over the phone at https://www.6ya.com/expert/uttamjeet_2f3adc18600f8ede
Jan 13, 2018 | Toyota Paseo Cars & Trucks
What dos vvt system malfunction it mean ?
Variable Valve Timing System Malfunction, and possible causes - dirty or low engine oil
- Valve timing
- Oil control valve
- Variable Valve Timing controller assembly
- Engine Control Module (ECM)
Read more: http://engine-codes.com/p1349_toyota.html#ixzz38fIMYdTd
Jul 27, 2014 | 1999 Daihatsu Sirion
Daihatsu problem
John the red flashing symbol is your mil lamp that is indicating a misfire condition and is an active code that reqires maintinence have a local parts place scan your obd2 port an run a scan on trouble codes most likely p0300 random misfire most probable cause is burnt out plugs or coil pack bad reccomend plugs an wires should fix that problem unless you have a stretched timing belt causeing misfires have it checked at a repar shop ask for codes an google it an it will tell you what the code means if the repar shop wint tell you. Be prepared for s tuneup
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
Jun 22, 2014 | 2005 Daihatsu Sirion
Power steering not working
Sirion 2006 model power steering system have some failure in EPS motor. remove your power steering motor and clean and fix it. power steering system will ok.
if it is not good tell me please what is the error code
if you don't know what is the error code you can check that your self's
Feb 03, 2013 | Daihatsu Sirion Cars & Trucks
Your engine is probably an EJ-DE twin cam 12 valve.
Generally Daihatsu belts have marks on them that line up with dimples on the sprockets for the intial phasing. You rotate the engine to top dead centre on No1 piston and install the belt from there. The cams should be not be putting any pressure on the intake and exhaust valves of No1 when phased correctly.
Aug 13, 2008 | 1988 Daihatsu Charade
Vehicle Parts & Accessories Logo
173 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
