Question about Panasonic CT-36D32 36" TV
Turning off PIP without remote
I lost the remote for this TV and the PIP window is open. Can I close this window without the remote?
  • Anonymous Aug 26, 2008
    PIP window is open and no remote! How do I close it? Help Please
  • valenmburke
    valenmburke Jun 14, 2012
    THANK GOD you posted this!!!!!!!!!
  • 3 Answers
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Posted on Jan 31, 2009
  • 2 more comments
  • PIXIEBARBER Feb 24, 2011
    THANK YOU SO MUCH!! YOU DO NOT KNOW HOW CRAZY THIS WAS DRIVING ME. YES THIS WORKS 100% FOR ME.
  • Patty May 06, 2012
    Hi, I tried everything else. I tried for five, long hours! Then I read this answer, and in 5 minutes the problem was solved. THANK YOU! THANK YOU! THANK YOU!
    Thank You so much! I had the same problem. I tried everything, for five, long hours. Then I tried your solution, and in five minutes, it was solved! Thank You! Thank You! Thank!
  • Deborah Cook Tener
    Deborah Cook Tener Sep 07, 2014
    Thank you! We have tried everything even ordering a replacement remote which did not work. Hours of research on google then came across this and it worked. Thank you so very much. This is awesome. Debbie
  • 790 Answers
No! you need the remote to close the pip viewer mode.
Posted on Sep 28, 2007
2 Suggested Answers
  • 395 Answers
SOURCE: Turning off PIP without remote
order the origanal remote from www.vancebaldwin.com the part number is RM-C380-1A the cost is $24.22 plus SH. there are a hand full of universal remotes that can control PIP but getting the right one a **** shoot.
Posted on Apr 19, 2008
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
I lost the remote and cannot remove the PIP.
Hi, I have the same TV, remote too. From what I can see you will need the remote to turn off the PIP, but if you unplug the TV and the plug it in again it may reset it to original values. As long as it is plugged it will retain certain low power settings.
If your Comcast remote is a learning remote, you can probably program it to mimic/replace the remote you lost, but you will need the codes from the Sony remote, or borrow one so the codes can be "learned" by the Comcast or some other learning remote. The codes would likely be available online, from Sony.
Worst case - I'll buy for you a cheap learning remote and dump the codes from mine if you want.
Also, you may find a used remote on line.
Mar 09, 2010 | Sony Televison & Video
Apr 19, 2008 | JVC AV-20120 TV
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Nov 29, 2007 | Zenith A27B33W 27" TV
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Panasonic CT-36D32 36" TV Logo
2,291 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
