Question about La Sportiva Tarantulace Kiwi/ Grey 2013
The eyelet (the metal ring where the lace comes out) popped out of my La Sportiva Tarantulace rock climbing shoes. What are the implications of this and should I/how do I fix this?
Shoe laces are weak
You dont give me much information. Are the eyelets OK? If not, they can rip the laces. Get nylon laces and they are stronger than cotton.
Mar 17, 2014 | Clothing Accessories
Tip
Tips on how to Choose Wear and Care for converse all star shoes
Buying Converse shoes is quite simple. Make sure one's just like the other, from the way the toe guard sits on the shoe to the distance between the eyelets. Check to see if the tongue pokes out about an inch over your laced-up shoelaces on each shoe.Here are some tips for wearing your converse shoes: •Wear quality socks that allow your feet to breathe.•Keep your laces untwisted within the eyelet space so they'll last longer and look fresher. •Make Converse your own by choosing laces in a different color or size. •Center the tongue of the shoe so they'll be more comfortable on your feet.•Make sure to confirm that wearing Converse will not create or magnify any foot problems. Bunyons, pronation, supination will all lead to more serious problems and later it will be harder to find shoes that fit and feel comfortable. When caring for your Converse shoes, just say no to bleach! Use soap and water to clean shoes without damage.
on Oct 27, 2010 | Clothing Accessories
Plastic shoelace eyelets breaking
Eyelets can be replaced at a shoe repair shop. I figure that the metal ones are better.
Dec 31, 2012 | Caterpillar Clothing Accessories
Are La Sportiva Typhoon boots suitable for use with crampons?
You can try to contact La Sportive directly and ask them:
http://www.sportiva.com/about/aboutus/about-us/contact
Jun 08, 2012 | Rock & Ice Climbing
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
I'm looking for a new rock climbing shoes.A friend of mine recommended me on 'Copperhead Climbing Shoe'. Any experience with this shoe guys?
I own it .So far, I like this shoe. First off, most 5.10 shoe toe shapes don't work for my feet (my second toe is as long as my big toe). However, this shoe provides a fit with no slop for my toes while allowing my toes to not be jammed up with their knuckles grinding through the top of the shoe.
For climbing, I'd say they do very well for trad climbing. Not as well for power-edging 5.11 and up, but just fine for easier stuff.Overall good shoe; would recommend it. .
How to remove inside door panel
It's usually the window winder that presents the problem . Remove all visable retaining screws ie; Grab handle , Internal door opening lever , Button on top of panel (if applicable ) etc . The majority panel are a pop snap on type . Remove the winder lever withthe aid of a shoe lace or thin piece of cloth material, The winder is retained by a horse-shoe shaped spring clip. .... Pull the shoe-lace/ material in the opposite direction of the winder retainer clip and it will easily come off, but it is a spring clip and may fly off so be careful. Good luck
Apr 10, 2010 | 2004 Mitsubishi Endeavor
Take off front door panel
Mar 22, 2010 | 2004 Ford E150
Climbing tools for beginners
For beginners, climbing shoes are a good investment as are chalk bags and a comfortable harness. Before anything, however, I'd highly recommend taking some climbing classes so that you know how to safely climb (i.e., tie in, belay, climb, etc.).
Dec 01, 2008 | Arc'Teryx M280 Mixed Climbing Harness
La Sportiva Tarantulace Kiwi/ Grey 2013 Logo
77 people viewed this question
Top La Sportiva Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a La Sportiva Winter Sport Expert? Answer questions, earn points and help others
