Question about Desa International Reddy Heater R40 40,000 BTU Kerosene Heater
Fuel tank on Desa R40 kerosene heater is rusty and corroded. This results in having to change the filter every other fill. I fill weekly with GOOD fuel and NO additives. I also screen fuel before filling. How can stainless steel rust and corrode? thank you
  • 3 Answers
Too much moisture will cause steel to rust or a low quality grade of steel.
Posted on Oct 22, 2013
3 Suggested Answers
tbugger
  • 232 Answers
SOURCE: my DESA C100D kerosene heater quits after running a while. It may
Emery- there are 2 types of filters used in the spark plug heaters.. Most likely yours is a long cylindrical type which is hidden inside the pickup tube that drops into the tank. These filters tend to get gummed up with a black, tar type goo that restricts fuel flow & starves the flame. The other is a lawnmower type filter. Go to this page for pictures of both types of filter.
The filter is probably the problem. The flame goes out due to lack of fuel, then the photocell shuts the heater down due to lack of flame.
Don't rule out water in the fuel. Water will cause a flameout condition, also.
Posted on Dec 20, 2008
  • 7 Answers
SOURCE: Grade of fuel required for DESA heater
Dave you can use all three types that you have listed.
The pump is typically set for Number 2/ Diesel Fuel and if you run Kerosene the unit will run a little bit hotter but with a 3E359B you will typically run diesel due to the amount it will use and the increased cost of kerosene over diesel fuel.
Number 1 is similar to kerosene and is the fraction that boils off right after gasoline.
Number 2 is the diesel fuel that trucks and some cars run on, leading to the name "road diesel". It is the same thing as heating oil.
Posted on Feb 10, 2010
Fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Jan 14, 2010 | Desa International Reddy Heater R40 40,000...
Heater will only work with top on. will not fire up with top on. when running with top off, will shut off when top is replaced
The fuel maybe contaminated,or you need some anti-gel additive to add to the fuel.Check the intake filter in the back,near the pump plate.
Jan 09, 2010 | Desa International Reddy Heater R40 40,000...
Burns your eyes while running
It appears that you need more combustion air and check intake filter
Dec 27, 2009 | Desa International Reddy Heater R40 40,000...
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
No start i cant see ignitor get brite red dont seem like im getting fuel
If the ignitor isn't glowing it isn't a fuel problem. It may be a pressure switch or bad ignitor.
Oct 04, 2009 | Desa International Reddy Heater R40 40,000...
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
My DESA C100D kerosene heater quits after running a while. It may
Dec 20, 2008 | Desa International Kerosene Portable...
Heating & Cooling Logo
98 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
