Bush WM-1260TVEME wash on a cotton wash when i heard noises that sounded like a firework been lit i turned round and orange sparks were coming out of top of display panel.i havent used it since this as happened ,could it be a manufacturing fault?
    Master:
  • 818 Answers
First unplug the machine if you haven't already-if your machine is less than a year old you should be under warranty-call the company that you bought it from-cheers Denny
Posted on Oct 23, 2013
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 210 Answers
SOURCE: LG direct drive washing machine WM-16220FD
This is a fun task. Not sure of this model number, whether it has a heater or not, if it does you can remove the heater and attempt to get out whatever it is out through there. The other way is to remove the bottom bellows, drain out the water through the drain trap first, this will give you a bit of access. The easiet way is to take the front panel off, otherwise you would have to tip the unit back, securing it, and trying to access it that way.
good luck.
Sgt 48
Posted on Jun 04, 2008
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: fault with WM-1480FHD LG washing machine, thumping
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#%@$#
Posted on Oct 01, 2010
ginko
  • 19396 Answers
SOURCE: I BROUGHT A BUSH WASHING
Hi.
Err 5 is water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water level switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Posted on Oct 29, 2010
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
Steering noise at turning left and right
If the noise is heard just at the steering wheel when turned left or right, then remove the steering wheel and apply a little multipurpose grease or white petroleum jelly on a brass band under the steering wheel.
If the noise is heard coming from under the engine bay, check the entire suspension system for worn out ball joints, tie rod ends, rack ends, rubber bushes and shock absorbers.
Sep 20, 2012 | 2000 Honda City
Hi my bush WM-1460TVE has been stuck on the same cycle 3.00 minutes for the past half hour it just goes round and round and is full of water still? Help?
Problem with the program controller unit. Remove the plug and power for some time and try again. If this wont work it is possible that unit has failed.
Jun 26, 2012 | LG Washing Machines
Bush wm-1260tveme require instruction manual
Sorry but FixYa cannot do that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 30, 2011 | Washing Machines
Rubbing noise heard when fan is on sounds like metal against metal
hi there, you need to replaced bushing, due to loose of shaft to the bushing the stator is mis align. thats why you heard a cracking sounds. thanks
Apr 30, 2011 | Hunter Fan Low Profile III Plus 20801...
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Error 5 means that there is a water inlet problem.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
