Question about Cameras
I have a olympus vg170 digital camera and it won't take pictures, it works fine when viewing pics already on the card but won't go from there to shot mode or switch off. The only way to switch it off is to go into view mode which closes the lens and and then push the power button. As it is at the moment if i try and power off it just goes through the lens in and out thing finishing with the lens out and not letting you shoot.
  • Cameras Master
  • 5,412 Answers
Sounds as if it is non-functional. Replacement will be cheaper than repair
Posted on Jul 09, 2017
4 Suggested Answers
SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Posted on Nov 22, 2006
  • 3 Answers
SOURCE: Olympus FE-340 camera i turn on the power the lens
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Posted on Sep 06, 2009
dlundmark
  • 797 Answers
SOURCE: I cANNOT OPEN THE LENS OF MY CAMERA. OLYMPUS TOUGH
Apparently some problem in the inside of the camera with the lens assembly or something is disconnected. You can get in touch with the repairs of the Olympus company and see what repairs would cost. I am almost sure that the repair is going to be more than the camera is worth to you.
Many times dirt or dust can cause problems with the lens. Also this can be caused by internal problems which means repairs. In my experience with these small cameras, the lens repairs have been some of the hardest repairs to complete correctly. That is not saying that it cannot be done. If the lens is taken apart or removed, the camera should be re-calculated on a computer with the right software.
Posted on Apr 15, 2010
When i open my fe-360 camera, in red is a message like.. "WRITE PROTECT".. I couldn't take a picture but I can view the pics being shot previously.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 11, 2010 | Olympus FE-360 Digital Camera
Pictures Lost???
Get an inexpensive card reader and try to download the pics to a folder you create on your desktop.
Nov 30, 2009 | Olympus SP-500 UZ Digital Camera
I am viewing pics on my D-560 and going from 1-200 pics is fine but then going to 201, the two lights on the camera start blinking and after a while the camera is shutdown. Going in reverse viewing form...
Sounds like you are keeping way too many pictures on the card. That's not safe. Download them to your computer using a separate card reader if necessary. Then format the card in the camera and start fresh.
Sep 01, 2009 | Olympus Camedia C-350 Digital Camera
Just received it back from tec support saying fine memory stick may need formating which i already explaned id done even with new stick, my problem been when you take pics photos going into file when you...
Hi you need to get the memory card a put it into your laptop and just put a few pictures on it, (it wont show on the camera when you view it) but after that put the memory card back into the camera and take a picture and you will be able to view it. i had the same problem, and just tried it now, and it works.
hope i helped.
Jun 30, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Can't download my pics from my cam to my comp !!!!!
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 15, 2009 | Olympus FE-210 Digital Camera
Xd card type
A Fuji card can be used in the camera; the only function that will be disabled is if you wish to take panorama shots with the camera. Panorama in the Olympus cameras is proprietary therefore in order to shoot panorama shots Olympus requires that you specifically use their xD picture card. Otherwise the Fuji card will work just fine.
Dec 10, 2008 | Olympus Stylus / mju 1050 SW Digital...
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
X-D picture error message.
Well, you can try to recover it using recovery software, but you are out of luck, it seems Olympus have some issue with memory card slot in FE model, I have FE280 and it happened to me three times already and I call the support they are no help what so ever. Answer they provide is format the card.
you can try to recover it using memory card reader, but you have to find one that support Xd slot.
Sorry to hear that you have that problem, take as lesson learn and don't buy Olympus.
Jan 27, 2008 | Olympus FE-230 Digital Camera
Olympus Stylus 750 Digital: Card error..cannot view pics or copy/download
its the card not the camera.
i think you fingers have come into contact with the gold bits on the xd card.
try wipping the card and putting it in several times,if all fails buy your self an olympus 1gb xd card H TYPE.
seekreep@yahoo.co.uk
the best compact of all time was the Olympus C-70 Zoom Camera which can be found 2nd hand over ebay.
Dec 21, 2007 | Olympus Stylus 750 Digital Camera
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
