Question about Izzo Swami 1500 Golf GPS Unit
I am trying to re register 1500 swami so i may charge and reload the program
My swami 3000 wont hold a charge
stop taking all day to golf,it should last 4 hours if not get a new battery
Apr 26, 2015 | Cars & Trucks
Have a PI-1500 Schumacher that I just got and trying to hook up to a litium Ion battery with charged voltage of 15.86 - lights on inverter light up(red and green) but no power output--- Is this battery...
you must be careful you can not interchange Lion and Nicad there voltages are not compatible and the intelliichargers will register a fault you must replace with same batterys recomended for your unit
Oct 24, 2013 | Schumacher PSI-1500 1500W Pwr Inverter
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Lost programming with power failure on te2400 have backup card but no instructions to reload program
This means the battery has failed. Since you will need to take the machine to a dealer to have the battery changed, give them the backup and they can restore your programming.
If anyone needs a Casio TE-2200 or TE-2400 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Aug 21, 2010 | Casio Parts Cash Register PC Desktop
My college student didn't register her Microsoft Office Home and Student 2007 on line. Her dad threw away the box that the program came in. She got viruses at college & had to reload the program and...
u can contact microsoft and the support person will ask for a no. that is on the inner layer of the cd .... once you give him the no. and if you have registered your version of the microsoft office .... they will charge about $10 and send you the product key ...
Mar 27, 2010 | Microsoft Office Home and Student 2007...
Reinstalling an upgrade --can't find the old serial number
try www.serial.us website. Or do a search on serail numbers for that particular program. If you register with the company they should email you your number.
Nov 09, 2009 | Computers & Internet
Royal Alpha 601sc cash register won't program.
Hi. I don't have a manual for that model. If you can flick me an electronic version, I'll try to help.
May 27, 2009 | Casio Parts Cash Register PC Desktop
I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
Apr 23, 2009 | Royal Office Equipment & Supplies
Power Lost during FirmWare Upgrade
Hi Swami Have a tech look at your set the problem could be more technical than you imagine.good luck
Apr 26, 2007 | Koss KS5190 System
Izzo Swami 1500 Golf GPS Unit Logo
41 people viewed this question
Top Izzo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Izzo Optic Expert? Answer questions, earn points and help others
