Question about Bosch Vacuums
Bosch formula 1400w - Bosch Vacuums
Need a manual for a shark SHKC7800 1400w 4.1ch. motorcycle audio system W/2 remotes FM,SD,usb bluetooth
Follow this link. On the right side one half way down should see download here. I started it to make sure it worked. Started fine so I canceled since I have no need.
For future reference most of the time you can find manuals by using model numbers etc followed by .pdf
Try it using you SHKC7800.pdf to see what I mean.
Good luck
Nov 26, 2014 | Shark Vacuums
Bosch hygienixx formula bsg71266gb/07.Lost my manual and would like a copy. Also can't work out how to empty the bag.
Hi. Visit http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html and follow the link to add the model number in. Also if no joy there contact Bosch UK - they will be happy to help you. Generally this vacuum has a bin door at the top that opens up towards the owner. The hose will have to be removed and the latch is behind the handle. Thereafter the bag can be slipped out and replaced.
Oct 29, 2013 | Bosch Vacuums
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Gary
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Not putting out any cleaning formula with the water
Is the mechanism the dispenses the formula working? The pump could be broken.
Jul 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Jul 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Can't refit dustbag to bosch ergomaxx barrel cleaner
The bag slips into the holder which should be attached to the machine. If you have taken this out by mistake and thrown it you'll have to contact Bosch to order a new bag holder.
Jan 22, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Vacuums Logo
19 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
