Question about Sylvania LC420SS8 LCD TV
What size screws fit slyvania lc320ssx? - Sylvania LC420SS8 LCD TV
What size Machine Screws do I need to mount a GPX Under Cabinet TV?
Um, "machine screws"? Unless you have a metal fitting inside the cabinet for those to screw to, you don't need machine screws.
Assuming you do have the metal fitting, then take that fitting to the hardware store to get the correct screws (and perhaps nuts). How long? Measure the thickness of the bottom of your cabinet, add the thickness of the bracket(s), and get the next size longer.
Jul 09, 2015 | GPX KCL8806DT 7 in. Portable Television
Need the size and thread pitch for my Delta disc/belt sander wheel set screw
Probably an 8-32 or 10-32 (possibly a 10-24) or even a 1/4-20. You can get small packs of these size screws at most hardware stores so would be cheap to busy one of each and try and once you know the size you can get a set screw of that size. Another crude way is to see what size drill bit will fit into the threaded hole. If a 3/32" goes but a 7/64" doesn't or fits tight, it is a size 6 (likely 32 threads per inch (TPI). If a 1/8" bit goes but a 9/64 doesn't or is really tight then it is a # 8 size. (8-32 is most common). If the 9/64 goes freely but a 5/32 doesn't it would likely be a 10-24 whereas if the 5/32 does go but an 11/64 doesn't then figure it to be a 10-32. Finally, it could be a 1/4-20 if a 3/16" bit goes but a 13/64 doesn't or is fairly tight. If it is really big and a 1/4" bit fits the hole then it is likely a 5/16-18.
Apr 18, 2015 | Delta 4" Belt 6" Disc Sander 31-460
I have lost the screws to my 50" soniq tv base. What size screws do I need
Buy an inexpensive screw hole size template (used for inserting screws of unknown size into it, and reading what size hole it fits into, and then going to buy that screw) at Home Depot (HD) or Loews. If there is room to lay the template over one of the holes, you can eyeball which hole on the template is about the same diameter of the screw hole on the base. Then go to the store and look for that size screw (machine screw Vs wood screw), and purchase one of each of three sizes (the one that appears to be the one, and one that is the next size down, and one that is one size larger. Then see which one fits in the base (this will be a bit of trial an error). This should work until the right size is identified.
Sep 19, 2014 | Televison & Video
How do I get the sylvania lc320ssx codes for fios ?
0029,0022,0067,0038.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 06, 2014 | Sylvania LC320SSX 32 in. LCD TV
RC5005 remote code for LC320SLX
go please to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jun 22, 2012 | Televison & Video
Sylvania LC320SSX HDTV no longer powers up.
Required power supply board is available in shopjimmy.com
Jun 09, 2011 | Sylvania LC320SSX 32 in. LCD TV
Neeed correct screw size for fan blades
go to the hardware and bring your orginal ones to buy exactly the correct size of screws theres a lot of screws being sold there.
Mar 21, 2009 | Heritage (4FNW42PT1M) 42'' Ceiling Fan
Sylvania LC420SS8 LCD TV Logo
19 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
