Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Lg wm2050cm will not spin or agitate. After cycle selected it tries to spin but sounds like a stripped gear or something. Panel removed off back and cannot rotate drum, it's like it's slipping.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Sounds like the clutch is bad
Posted on Oct 22, 2013
Testimonial: "I am wondering about the rotor, the gears in particular. Should I be able to spin the drum by spinning the rotor by hand? It appears the gears are really warn. I can spin the whole tub by installing 17mm socket and turning drum"
  • Mike Biseinere Oct 22, 2013
    It appears I answered my own question. The plastic piece attached to rotor was so worn that the gear was not turning the rotor around stator. I tightened the mess out of it and it works!
  • 209 Answers
SOURCE: Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Posted on Sep 19, 2007
  • 126 Answers
SOURCE: Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Posted on Jan 12, 2008
SearsTechToo
  • 261 Answers
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Posted on Oct 08, 2008
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
  • 1937 Answers
SOURCE: I have a Kenmore 90 series Model # 110.28902790,
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28902790
Please see the Whirlpool Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the Whirlpool Parts list for their commercial washers although the consumer models use the same parts.
The problem points to a worn Agitate Cam.
Whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
The cam is a two piece plastic part that lifts a gear above the main agitate assembly in the transmission so that the agitator doesn't turn during the spin cycle.
We had the same problem. The cams had worn enough that they weren't lifting the gear (less than 1/16").
They aren't expensive at all but do require pulling the transmission.
See the following for a description of how to remove the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to remove the tub!!
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It may seem like a difficult job but it really isn't. It is a bet messy but it's a lot less expensive than a $170 transmission.
Posted on Nov 06, 2009
Testimonial: "Thank you so much! I have the parts on order and will repair it in a few days."
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Spin cycle for tub broken - no spin, sounds like gears stripped.
Hi Ed can you please give model # and make so we can give better advice thanks.
Nov 17, 2009 | Kitchen Ranges
Agitator won't spin
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Washing Machines
Agitator not spinning hear sounds inside the shaft
Hi, this agitator may have stripped all of the internal gears and plastic drive adapters that allow it to preform its actions during the selected cycles. The only solution here will be to replace the agitator and drive shaft as well. you can order a complete agitator kit with all the parts as well. this will fix this issue. Please rate and god bless:)
Apr 13, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
