Question about Briggs & Stratton Garden
Model #917388861 will not throttle up - Briggs & Stratton Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Well does it start and run ok otherwise ??? if yes, then check your engine speed adjustment... if you have a primer bulb the adjuster is above that. this is something a shop should do because it's a specific rpm and catastrophic damage could result from over revving. if no, we need more info
Posted on Oct 24, 2013
P1172 code for polo 2004 model what effect does it have
Faulty Throttle Position Sensor (TPS)
  • Throttle Position Sensor (TPS) harness is open or shorted
  • Throttle Position Sensor (TPS) circuit poor electrical connection
  • Faulty Throttle Drive electric motor
  • Faulty Throttle Valve Control Module
  • Oct 21, 2017 | Cars & Trucks
    Where is the position of throttle sensor of murano 2004 model
    The throttle position sensor is incorporated into the electronic throttle control motor located on the side of the throttle bore where the air hose from the air filter box meets the throttle assembly
    Dec 29, 2015 | Cars & Trucks
    Is the idle control valve part of the electronic throttle body.
    What is year--make--model? With electronic throttle, you probably have a throttle pedal position sensor as well as whatever is on the actual throttle-body? Usually the iac is part of the throttle-body.
    Jul 31, 2015 | Cars & Trucks
    Can i change just the censor in the throttle body on my 2005 pontiac g6
    On your car and many newer model cars the throttle body is one piece, with a built in tps/throttle position sensor. On older models they were serviceable. You could try cleaning the mechanical part of the throttle body, and see if that helps.
    Feb 18, 2015 | 2005 Pontiac G6
    How do I solve for My Hyundai sonata model 2009 code P2110 , P2118 in scaning. I changed throttle body and TP sensor. after change of these even I am getting problem in accelerator not increases above
    P2110...Faulty Throttle Actuator Control Module
    - Throttle Actuator Control Module harness is open or shorted
    - Throttle Actuator Control Module circuit poor electrical connection
    P2118 - Electronic Throttle Control(ETC) system is made of the components throttle body, Throttle Position Sensor(TPS)1&2 and Accelerator Position Sensor(APS) 1&2. The throttle body contains the actuator, the throttle plate and the throttle position sensor (potentiometer), which are integrated in one housing. The actuator consists of a DC motor with a two-stage gear. The opening angle of the throttle valve is detected by the throttle position sensor which is mounted on the throttle body. And it provides feedback to the ECM to control the throttle motor in order to control the throttle valve opening angle properly in response to the driving condition.
    Jan 06, 2015 | 2009 Hyundai Sonata
    How to install a throttle cable model 3120xp
    Instructions
    1 Push the end of the new throttle cable onto the linkage on the carburetor, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
    2 Place the throttle cable clip over the linkage. You may need to pry the end up with a flat-head screwdriver to get it in place.
    3 Secure the throttle cable in the throttle cable bracket located on the intake manifold. This, too, should clip into place.
    4 Route the cable into the cab, being sure to keep it kink-free.
    5 Loop the end onto the end of the accelerator pedal inside of the linkage hole. In other vehicles, there may be a clip on the accelerator pedal that holds the throttle cable in place, which is also easy to do with your bare hands.
    Jun 24, 2014 | Husqvarna Garden
    Craftman model 917.271920 run at high speed at the time.even with the throttle in idle position
    If a cable operated throttle the far end of the cable may have broken or come off. Linkage between throttle cable and carburetor bent/broken/
    missing, spring broken/missing. Shouldn't be too serious.
    Apr 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Rpm maxes out and I can't bring it down
    check that throttle linkage is ok and free, check that throttle plate is free to move and not jammed - check that srew in the throttle plate is not allowing plate to restrict and jamb throttle
    check the governor springs and links are in the correct places and are free to move , check that governor is working ?
    if its not migght be governor is adjusted wrong or slipped
    or its flown to peices
    if unit is ohv model have seen the the ocilating balancer
    torque link rod break and cause a engine to go to full throttle
    as sson aas the engine was started
    please let me know model and type numbers off the engine in question and its make ie briggs etc
    and will try help further
    cheers paul
    Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
    Three (3) possible carbs were available on your machine.
    If you have:
    Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
    If you have:
    ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
    If you have:
    ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
    Hope this helps.
    Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Code p0121 TPS
    THERE IS A TP SENSOR BUILT INTO THE THROTTLE ACTUATOR. THESE TRUCKS HAVE BEEN KNOWN FOR A FEW PROBLEMS IN THIS AREA. THROTTLE ACTUATOR IS NOT SERVICEABLE. THE THROTTLE BODY WILL NEED TO BE REPLACED IF IT IS PROVEN FAULTY. THE APP SENSORS ARE LOCATED IN THE GAS PEDAL MODULE. THESE SEND SIGNAL TO COMPUTER TO TELL IT WHERE YOUR FOOT IS, THEN COMPUTER SENDS COMMAND TO THROTTLE ACTUATOR TO OPEN OR CLOSE THROTTLE BASED ON THIS INPUT. THE SENSOR IN THE THROTTLE ACTUATOR DELIVERS A MESSAGE BACK TO THE COMPUTER TO TELL IT WHAT THE ACTUAL THROTTLE POSITION IS. IF THESE SIGNALS DONT MATCH(WHERE THROTTLE IS COMMANDED AND WHERE IT ACTUALLY IS)THE CHECK ENGINE LIGHT WILL ILLUMINATE AND THE VEHICLE COULD GO INTO A REDUCED POWER MODE. HOPE THIS HELPS YOU!
    Sep 07, 2009 | 2007 Chevrolet Silverado 1500 2WD
    Garden Logo
    53 people viewed this question
    Top Briggs & Stratton Garden Experts
    Phil Walker
    Phil Walker
    John Trevino
    donald boissonneault
    Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
