Question about Mizerak Dynasty Space Saver 78" Pool Table
Lost the screws for a Mizerak Dynasty Pool Table 78-inch (need to know know what size screws to buy for the legs)
Toshiba 40BL702B lost table top stand screws
You can find the screws in your local hardware store.
Jan 17, 2014 | Toshiba Televison & Video
Tip
Turn Travel Trunk into a Coffee Table
Making your old travel trunk into a coffee table can be a very good feature to add to your decore and can be a great conversation starting piece. The best part is that turining it into a coffee table is not a very difficult thing to do.
Most travel trunks are a little too short to be a proper coffee table so you are going to want to find some table legs that you like and cut them down to the height that you want the table to be at. If they are wood you can even stain them to match the trunk or other furniture in your house.
Things you are going to need:
- A travel trunk
- 4 table leg straight top plates
- 4 table legs
- screws and a drill
If you are going to stain the legs then you should stain the legs before you start and allow them to dry.
Using the drill screw the table leg plates to the corners on the underside of the trunk. Once the legs dry screw them into the leg plates and flit the trunk over. And walla! you have a brand new vintage coffee table.
on Oct 21, 2013 | Luggage & Travel
I want to buy a pool table for my basement, but I don't know if the room is big enough. How big of a room do I need for a billiard table?
It obviously depends of what size table you are buying. I found you a great chart that outlines the various table sizes and the dimensions the room should be for each.
Jul 25, 2012 | Sport & Outdoor - Others
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
I need a diagonal mirror and eyepiece or eyepieces for a 78-9512.
These come in 3 sizes .965 inch, 1.25 inch, and 2 inch-- measure the hole in the focuser and buy the correct size. Many on-line retailers sell diagonals and eyepieces. Here are two:
http://www.agenaastro.com/
http://shop.telescope-warehouse.com/
Jun 03, 2011 | Bushnell Optics
Where can i buy new Bushnell Voyager 78-9675 eye pieces and spoter scope
Many on line retailers sell eyepieces. They come in three sizes, .965, 1.25, and 2 inch.
Measure the hole in the focuser. The .965 inch size is harder to find.
Here are two retailers who sell eyepieces:
Sep 14, 2010 | Bushnell Voyager 78-9945 Telescope
I need an eye piece for a Bushnell AK-78-9440 Telescope
Eyepieces are either .965 inch or 1.25 inch in size. Measure the hole. You can buy eyepieces from many on line astronomy shops. Here are two:
http://www.agenaastro.com/Telescope-Eyepiece-s/3.htm
http://www.optcorp.com/
Oct 09, 2009 | Bushnell Voyager 78-9440 (440 x 12.5mm)...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Gas line BSU"s
3/4 inch pipe is first choice but 1/2 inch pipe will work.
Aug 21, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Mizerak Dynasty Space Saver 78" Pool Table Logo
Top Mizerak Sport & Outdoor - Others Experts
Are you a Mizerak Sport and Outdoor - Other Expert? Answer questions, earn points and help others
