Question about Kitchen Appliances - Others
I need a part to hold the thread. where can i get replacement parts for omega 373
3 Suggested Answers
  • 1116 Answers
SOURCE: need an online manual on new home 373
You might be able to get a free manual from the Janome website.
I found this $5.00 download - http://brubakerssewing.com/store/index.php/sewing-machine-accessories/janome-l372-l373-instruction-book.html
Posted on Apr 29, 2010
bargainbox
  • 1388 Answers
SOURCE: omega model 373
It may be either or a combination of these two things.
Lint/Thread etc in top tension, for which this tutorial will be beneficial:
http://www.sendspace.com/pro/wt7kfh
....or....
Timing of Hook to Needle, for which this set of diagrams will be beneficial in general terms:
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
It may be necessary to then dig deeper, but further specific detail will depend on the level of detail you have required initially when posting the question.
In the event please use THIS LINK and ask for "Bargainbox"
We recommend a General Service every 12-24 months, just like your car needs tuning, no less this rather complex machine.
Cheers
Martyn
Bargain Box Fabrics
Posted on Oct 25, 2011
Do the omega 420 handle upholstry thread
Most domestic machines would have difficulty using upholstery thread. Upholstery thread is generally very heavy so the tension settings would need to be adjusted on the machines. Evenso, the tension mechanisms adjustments still may not be enough to accommodate heavy upholstery thread.
Even if your machine can accommodate the thread, your machine's motor could be compromised trying to sew upholstery fabric.
Oct 19, 2017 | Omega Sewing Machines
I need a diagram of how to thread my Adler 267-GK-373 leather sewing machine and a manual also
For the manual, try Googling (adler)(267-GK-373)(manual) without parens.
Mar 04, 2017 | Sewing Machines
Omega model 373
....or....
Cheers
Martyn
Bargain Box Fabrics
Oct 24, 2011 | Euro-Pro 373 Mechanical Sewing Machine
Needle does not pick up bobbin thread on my 373 sewing machine, flipping the bobbin does not work, as someone suggested.
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Jun 11, 2009 | Euro-Pro 373 Mechanical Sewing Machine
How to oil euro-pro 373?
Have you tried flipping the bobbin in it's case, so that the thread comes off the top of the bobbin instead of the bottom. Some machines are sensitive to one direction of the bobbin thread.
Dec 04, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Oct 09, 2006 | Euro-Pro 373 Mechanical Sewing Machine
Kitchen Appliances - Others Logo
200 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
