Question about Lexmark P315 InkJet Photo Printer
Reset lexmark cartridge 33 - Lexmark P315 InkJet Photo Printer
SOURCE: How can I reset my
I have same problem, tried print head alignment but no results. Will not recognize refilled cartridge. HELP!!
Posted on Jul 01, 2008
SOURCE: Lexmark X5250 Printer
chech to see if the cartridge slot locks down the tab that locks the cartridge have been known to break. or run a maintenance check and clean the printer heads.
Posted on Nov 05, 2008
SOURCE: RResetting Cartridges after refilling
Can't be reset. The Lexmark 32 & 33 (and porbably som others) contain a low ink sensor in the cartridge that once activated can NOT be reset. The key would be you have to refill before the low ink sensor gets activated. Don't know at what ink level that is, probably around 1/4 remaining.
Posted on Apr 15, 2009
  • 159 Answers
SOURCE: installeds a refilled colour cartridge and will
Using a refill for this printer will not "do damage." The damage they are referring to is if you continue printing with an empty cartridge you can damage the print head on the cartridge. Since you replace the print head every time you replace the cartridge, you never damage your printer.
Posted on Mar 08, 2010
pineworks
  • 4041 Answers
SOURCE: I ordered Lexmark 32 & 33 ink cartridges off
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
Replacement color cartridge is not shaped the same as the original color cartridge and does not fit into the cartridge slot.
Make sure you are inserting the correct cartridge versions in your Lexmark printer. The Lexmark X5470 uses the 32/34 black cartridge and 33/35 color cartridges.
If these are the cartridges you are inserting, please contact Lexmark Technical Support Center for additional assistance.
Aug 17, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5470 says: incorrect right cartridge. I have insert new lexmark cartrdge no.35, after that anew cartridge lexmark no.33, and the printer says the same, even when the carrier is empty. I have...
Try to remove both black and color cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert both cartridges and make sure they are properly seated and secured in the carrier. Close the cover. If error continues to show on the display screen even if interchangeably insert your 35 or 33 cartridge, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Computer says that the cartridges are in the wrong slots- which they are not. I have tried switching off and on -no effect, same message.Error 1102 The only thing that is different than usul is that I...
Turn the printer off.
Disconnect the AC power cable from the wall-outlet, to make sure that is "100%-OFF".
Reconnect it.
Remove that #33 cartridge.
Does that get rid of the "wrong" message?
Reinsert that #33 cartridge.
Does that message still appear?
Have you returned the "defective" #33 cartridge to where you bought it, and gotten a replacement for it, and installed that replacement cartridge?
Mar 25, 2011 | Lexmark X3650 Printer
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark X5470 bought a lexmark #33 color cartridge. the printer states: right cartridge incorrect. at the store it said that it is compatable with my printer. how do i get my printer to work?
According to the Lexmark site an number 33 color cartridge is the correct color cartridge for the printer.
Are you trying to print potographs? If so, then you would need the #32 cartridge and the color cartridge together in the priter.
If you believe that the cartridge is defective, contact Lexmark at 1-800-232-3000 and let them know you received a defective cartidge.
Don
Jun 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
Apr 15, 2009 | Lexmark X5250 All-In-One InkJet Printer
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark printer 810 series what number for a black ink cartridge
series it would be 18C0032 (Lexmark 32) Black remanufactured cartridge 18c0032.jpg
Apr 03, 2008 | Office Equipment & Supplies
Lexmark P315 InkJet Photo Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
