I need a repair manual for a 2004 ford mondeo 2ly tdci
  • 5 Answers
SOURCE: mondeo tdci
hi there, you will need a diagnostic check carried out to locate the exact fault, most garages have the equipment to carry out these checks so you won't need to visit your ford agent, a common fault on the engines is the camshaft sensor these cost around £20 and are very easy to replace, however once you have it tested you will now your exact fault, hope this helps
Posted on Oct 24, 2008
TLRogue
  • 99 Answers
SOURCE: ford mondeo bonnet lock
This is a very common fault on the fords, if i get one in, i generally soak it in WD40 then keep working it back and forward untill the mechanism releases.
If the lock is completely gone then ive had to go as far as breaking the grille off and opening it manually with a scrrewdriver, but this is last resort.
Good luck
TL
Posted on Feb 04, 2009
ajarema
  • 404 Answers
SOURCE: 06 ford focus 1.6 tdci, fault code p2585 showing.
There are only p258 a-f codes and there is no p2585, anyway it is either vacuum pump problem, normally solved by checking or replacing the wiring or it is torque management system and it is also related to wiring. In both you need to get a proper reading of code again and than check wires after that get the test done again.
Posted on Jan 20, 2011
SOURCE: 2004 Ford Mondeo Sony 6cd radio manual
Ford 6006CD 6 change. I have the code! how do enter it?
Posted on Jun 29, 2011
  • 98 Answers
SOURCE: ive got ford mondeo tdci 54 plate.. ive just had the dual mass flywheel replaced but now the clutch is playing up it goes stiff and wont go into gear, could this be it needs clutch fluid??
Angela, I'll be honest I'm confused. It shows "problem with Toytoa Celica" but you mention a Ford Mondeo in your post. Just to be sure we're talking about a Ford Mondeo that had the flywheel replaced, correct? Chances are if they replaced the flywheel you normally would always replace the clutch disk with it. If this is a hydraulic clutch system you don't typically have to open the hydraulic system to swap out the flywheel and clutch on a car. This would lead me to believe clutch fluid isn't your answer, but I would at least make sure you check it. If they DID have to open the system the clutch needs to have the air bled out of the hydraulic lines.
Posted on Nov 24, 2012
Why is there no pulse at injectors on a 05 mondeo tdci
No pulse? Is the engine running? How are you measureing pulse? If the engine is running there is a pulse, if it's not running, there won't be a pulse. If TDCI is correct this is a turbodiesel
Compression Ignition.
Mar 12, 2015 | 2005 Ford Mondeo
Ford Mondeo tdci fault code says speed sensor causing loss of power?
replace the speed sensor and rerun the fault codes as this unit may be restricting the engine operation and put it in limp mode.
Apr 12, 2014 | 2004 Ford GT
Ford mondeo ghia x tdci 2002 power problem
split intercooler hose, happened to mine do you hear a sucking noise when accelerating? new hose costs about 40 quid main dealer only
Jul 08, 2010 | 2004 Ford GT
Will a 2003 mondeo tdci engine fit into a 2002 mondeo tdci
They should be. The SVT Models stay Very Consistent on the Motors.
Jan 21, 2009 | 2002 Ford SVT Focus
Mondeo tdci
Oct 23, 2008 | 2000 Ford Focus
22 people viewed this question
 Grubhead
Grubhead
