Maxell usb memory stick
My 8gb said i needed to format it to use it but it wouldnt let me, now it isnt showing up computer and i cant use it at all?
    Top Expert:
  • Computers & ... Master
  • 22,162 Answers
Either your computer cannot format in FAT32 being the default format type, the format failed or the USB stick has developed a fault.
Posted on Oct 22, 2013
SOURCE: Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Posted on Mar 08, 2009
  • 40 Answers
SOURCE: maxell usb 8gb HDD will not open?
for best result (and sure) go to device manager ,select there your usb , click for property ,at policies select OPTIMIZED FOR BEST PERFORMANCE.it should aloud you to format in ntfs wich it's more reliable format.
Posted on Apr 19, 2010
  • 10406 Answers
SOURCE: Hi! I have a Verbatim 8GB
Throw it away (after taking a hammer to it, so that any "data" on it will definitely _NOT_ be able to be recovered). Then, for less than $20, buy a replacement.
Or, check the manufacturer's web-site. If it is still under warranty, maybe they will replace it, at minimal cost to you.
Posted on Nov 01, 2010
  • 14 Answers
SOURCE: My computer doesn't recognize my
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Posted on Aug 19, 2011
bronk50
  • 27725 Answers
SOURCE: My 8GB Sandisk Cruzer Micro
here are a list of fixes for usb drives
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
((I have found better results ticking the first box then reurn and tick the second box)) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps you
Posted on Sep 17, 2011
When I put in 16 GB Maxell memory stick into my MacBook Pro it does not acknowledge it. The package says it is compatible with MAC but this one is not working.
Try reformatting on another computer in a more compatible format. Also try to find in the finder and right click and look into the formatting options.
Dec 12, 2014 | Maxell 16GB USB Slider 2.0 Flash Drive...
How do I remowe wrightprotection on maxell usb drive
Assuming you have Windows 7 - click on start > right click on Computer > manage > Disk Managment on the left > select the usb drive from the menu at the bottom > right click and format, Name it whatever you want. If you want to copy files over 4gb then select NTFS if not then stick with FAT32. Leave allocation unit size as it is. Make sure there is a tick next to Perform a quick format (unless it fails then untick it) then format. Please note that these steps will completely wipe your usb stick of any content it currently has.
Nov 25, 2014 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
When I plug my Maxell 8Gb 360 usb thumb drive into my computer at work, which is running XP, the OS can see the whole 8Gb, but I cannot put a 4Gb file on the stick. However when I use my windows 7 laptop...
Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
Jan 06, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
My 8gb microSDHC memory card fits in my phone, but no memory card shows up
The memory card may have to be formatted for the phone with the phones format procedure via the PC and the proper software.
Apr 19, 2010 | SanDisk 8GB microSDHC Memory Card with...
Maxell (messenger) 8GB USB memory stick inaccessible
sorry do not beleve that you can save that part if you can copy what is left try to than format it then reinstall on it jim
Mar 26, 2010 | Computers & Internet
Maxell 8gb stick now has Raw file system?
Hi
No unfortunatley this drive has been corrupted and will need to be replaced
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Electronics - Others
I have an 8gb maxell usb memory stick which asks for passwords with ''Unlock an Enhanced memory stick''. I put in the password but nothing seems to unlock it. There is nothing on the disk as it is a few...
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 06, 2010 | Electronics - Others
Cant read instructiom on usb purple memory stick.ask for password,new stick please explain how to use
if the sd card is not showing on the pc then try going to the menu on your camera and there should be a pic of a memory stick. if so click on
it and click format.
Aug 18, 2009 | Maxell Electronics - Others
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
