Fault code p1934 on s type jag 2.7d only since drove through deep puddle
    Master:
  • 818 Answers
Autozone pepboys or advanced auto will hook up and diagnose problems for free-I suggest you dump the jag and get a nice lotus 7 and a good cap-cheers Denny
Posted on Oct 23, 2013
I have a 2004 Jag s type w/ 45k miles. Last night I got all the system lights and "transmission fault, parkbrake fault and dsc not available." Got home, turned it off, restarted after 1 minute, restarted...
First thing to do is get the battery checked and replaced if necessary. If the problem continues, it will be necessary to have a pro-shop check the fault codes (go to a Jag specialst, not a dealer)
May 04, 2014 | 2004 Jaguar S Type
Fault code p1934 and limited power and sometimes engine management light this only happened since I drove through a deep puddle but the problem now only occurs when it's raining no problem when it's dry
Check the water proof covering of all the wiring connections as there is one that has failed and allowing water into the connection when it is wet . Seal with spray wax after drying out the connection
Oct 22, 2013 | Jaguar Cars & Trucks
Volvo through a puddle
Go to autozone,they will scan for free and tell you want is wrong.
May 26, 2013 | 2000 Volvo S80
I have a 97 ford Taurus I went through a few puddles going 40+ they were kinda deep after I drove away my car turned off then I wait like 15 mins it started after a few try's drove it around went home...
Its probably ok. You may have caused the crank sensor to stop working.
If the check engine light is on I would have the computer checked for trouble codes.
May 18, 2013 | Cars & Trucks
Cruise not available fault light on 2004 jaguar s type 3.0 v 6
What is the fault code? If you don't know you need to have it tested with a scanner that reads all JAG codes, that means the dealer.
Apr 07, 2013 | 2004 Jaguar S Type
Drove through a puddle,power steering out and temp gauge on high, battery light on
I've seen it happen many times on the older Caravans, if you hit a really deep puddle, the splash can knock the accessory drive belt off of its pulleys. You can just gently pry the belt back on, consult a service manual for detailed installation directions.
May 08, 2012 | 1998 Dodge Caravan
4.6 northstar drove through puddle car died does not turnover
with the plugs out use a socket and johnson bar on the crankshaft and turn the engine over, it should turn over fairly easy
May 25, 2010 | 2002 Cadillac Seville
My son drove his charger thru a deep puddle. the
Does the engine turn fully or not? If not the connecting rods are more than likely twisted to your pistons if he hit the deep puddle at a fast rate of speed. The pressure of the water would of passed through the engine's crack seal producing deadly effects to the engine
Jan 20, 2010 | 2008 Dodge Charger
Engine mangement light on jag s type fault code p1577 how do you fix the fault
hi your codes =p power 5 vehicle speed / idle control 7 transmission hpoe this helps please rate this answer thanks
Nov 23, 2009 | 2000 Jaguar S-Type
Open Questions:
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
