Question about Samsung NP-N130-JA01US Netbook
How to boot to CMOS - Samsung NP-N130-JA01US Netbook
    Scholar:
  • 79 Answers
Hey Robert, try F2. Some new computers may have it as F1. I hope this helps, give me your feedback if it does not. Good luck.
- Joe
Posted on Oct 22, 2013
What can I do to boot my PC without using the F8 key?
If you have to select the boot device every time, this means that the BIOS (CMOS) setup does not have the boot device listed as the first device to boot from. At startup, press the key that enters CMOS (BIOS), usually DELETE, or possibly F2. Once in the CMOS, look for boot options, then boot devices, then boot sequence. Find your device and ensure that it is listed first in the boot order sequence. Then save the changes and reboot. You may have it set for a USB or network boot first and it won't boot without intervention.
Aug 15, 2016 | Computers & Internet
I forgot my cmos password what will i do to reset it
You're out of luck. A forgotten CMOS password cannot be bypassed or reset. You are stuck with a locked CMOS.
This only means the CMOS settings are not accessible. This shouldn't stop your computer from booting. That would be the CMOS boot-up password. If you can boot you can reformat. But, you cannot reformat (flash) the locked CMOS.
If you can't boot into the O/S then you're stuck until you can remember your CMOS boot-up password.
Next time, write it down and keep it safe.
Feb 28, 2015 | Computers & Internet
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
Hp compaq nc6230 boot from usb
Most PCs will not boot usb, unless the CMOS setup configure supports that device as a boot choice on cold start. F10 or does allow whatever key strokes needed before windows logo, will get you into CMOS config. Then look for boot, sequence and see if the usb is an option, if not, no hope for usb boot.
If CMOS config does allow usb boot AND your usb device has been set up to be a boot device,(and you saved the cmos changes) with the proper files...
shut dow, put in usb and cold start.... save
Jan 28, 2014 | HP Compaq nc6320 Notebook
Aspire 3690
  1. Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
Finally, if none of the above suggestions resolve this error go through the Invalid or Non System Disk error troubleshooting steps, which is related to this error message.
Dec 17, 2013 | Acer Aspire Computers & Internet
Schematic for toshiba p200d-12kbecause i need to change the cmos battery
The CMOS battery will not prohibit the machine from powering on. If you're prompted before boot about the CMOS battery, you should be able to press whatever key-combination it asks for to move forward to boot. Otherwise, you have a separate problem.
Nov 16, 2012 | Computers & Internet
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
How can remove the cmos password
hi, if you know how to open a computer or laptop, just remove the cmos battery, it is a round shape silver battery just like the battery for wrist watch but its like 3 or 4 times bigger than the regular wrist watch battery,...just remove the cmos battery then boot up your computer then, after booting up, shutdown your computer then put back again the cmos battery, then boot up again your computer then you can go directly on your cmos, it will not prompt you for any password
regards
Dec 04, 2010 | Computers & Internet
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
Samsung NP-N130-JA01US Netbook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
