Question about Panasonic KXDT343 Phone
I set up my voicemail according to instructions (twice) but whenever someone calls into my voicemail it just rings and rings -- nothing picks up.
    Problem Solver:
  • 13 Answers
Make sure the setting is turned on
Posted on Oct 22, 2013
cnavarro
  • 2460 Answers
SOURCE: KX t7453 Voicemail not picking up
Try dialing 710x 165 (#) from the intercom on your phone, where x=2 for all calls, 3 for busy 4 for no answer and 5 for no answer/busy. Once you dial it, the FWD light should blink and if you press it again it will go out.
You probably just canceled the original setting.
Carl
Posted on Oct 31, 2008
  • 3 Answers
SOURCE: My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Posted on Jan 16, 2009
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Posted on Jan 22, 2009
cnavarro
  • 2460 Answers
SOURCE: # of rings before voicemail picks up
Yes there is, but you have to know multiplication :-)
At the extension, from the intercom dial *713 and the 2-digit time in seconds. An internal ring cycle is about 6 seconds. I think the default time comes from the system and it may be 40 seconds.
Carl
Posted on Mar 23, 2009
cnavarro
  • 2460 Answers
SOURCE: I can't find out how to set the number of rings before my phone goes to voicemail
The system CF timer is something obscenely long, like maybe 40 seconds. Each user can change it by dialing *713 and a 2 digit number from 00 to 99.
Carl
Posted on May 07, 2009
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Incoming calls
Who is your carrier? the voice mail is set up via them call or web site. Your phone rings or not rings check ringer volume and ring tone and check if you always have a good signal.
Mar 07, 2014 | everbuying Cheap Unlocked Phone 5.0 inch...
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
How do you set up the voicemail on the nokia 6600i. Whenever someone rings me it just rings on forever rather than going through to voicemail. I'm on T-mobile. Cheers Tim
If the phone just rings and it does not go to voicemail then there is a problem with the voicemail feature on your account. Odds are the feature is missing and needs to be added or readded to the account. Your best bet is to contact T-mobile and have them readd the feature. Have them test and make sure that you can access the voicemail before they end the call to ensure they have fixed the problem. Hope this helped.
Apr 01, 2010 | Nokia 6600i Slide Cell Phone
Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Broken voicemail
is this phone a GSM phone by any chance?
Nov 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Answering machine not working
change how many rings your voicemail picks up in or cancel it.
set your answering machine to less rings than your voicemail.
Aug 29, 2007 | GE Telephone pr521w
Panasonic KXDT343   Phone Logo
80 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
