Question about Canon PIXMA Office Equipment & Supplies
Canon pixma mp495 encoder strip came lose how to reposition.
4 Suggested Answers
  • 10406 Answers
SOURCE: how to install a canon pixma mp495 printer with no
CANON puts its device-drivers onto its web-site: http://www.canon.com
Click "Support" or "Downloads".
Enter your model-number.
Select your Operating System.
Download the device-driver.
Install it.
Print.
Posted on Feb 01, 2011
Testimonial: "You guys are awesome thanks"
SOURCE: Trying to connect iPad to
How do I connect canon mp495 to my I pad?
Posted on Feb 17, 2011
  • 29 Answers
SOURCE: error 5200 or P08 on
The error indicates the following : Head overheating error.
Yes it is most likely the print head itself or at worst the logic board.
Replace head/logic board is the only answer.
Posted on Jul 20, 2011
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
May 11, 2012 | Canon PIXMA MP495 InkJet Printer
What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
Jan 29, 2012 | Canon PIXMA MP495 InkJet Printer
Tried pushing the comcast router WPS button to set it with the printer, but its not working. help
Hi there :first your router must be " A commercial access point or router that supports IEEE802.11b/g/n is required. "You have to do the installation two times , folow this link :http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP495.aspx?faqtcmuri=tcm:14-774514&page=1&type=faq
I hope this information will help you.
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
Hardware error 0502 from A dell 940
Here is how to fix error 502.
Rick
ยป Reposition the Encoder Strip on the A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Jun 14, 2011 | Dell A940 All-In-One InkJet Printer
Put encoder strip in mp140
I have the same problem... somebody helpme?
Apr 27, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Canon printer crashes and bangs around when printing. Any Idea what's going on?
If printer crashes and bangs then their is the problem with the encoder strip it might have been broken or misaligned you need to look for the transparent tape in the printer which is encoder strip ......Or get it replaced this will solve the problem ...
Oct 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Jul 28, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
87 people viewed this question
old marine
old marine
