Ducane gas furnace green light flashing furnace will not kick on shuts off
THENTHEREWER
  • 131 Answers
SOURCE: everything is operating fine but
COULD POSSIBLY BE A BAD IGNIGHTER.I DON'T KNOW THIS SYTEM BUT THE SAFTY PROTOCALS ARE WORKING.THE THERMOCOUPLE(IT DETECTS HEAT)IS TELLING THE BOARD IT HAS NO IGNITION,THEREFORE KEEPING YOU FROM BLOWING YOUR HOUSE UP.IF IGNITION HAS'NT HAPPENED WITHIN A FEW SECONDS IT SHUTS THE GAS OFF.IF YOU DON'T KNOW WHAT YOUR DOING DON'T MESS WITH IT,.IF YOU GET INTO THE WRONG THING YOU WILL ALLOW NATURAL GAS OR PROPANE TO LEAK INTO YOUR HOME(THIS IS A BAD THING)THE COTROL BOARD BLINKING IS A TROUBLE CODE.USE YOUR OWN JUDGEMENT.IF YOU NEED FURTHER HELP CONTACT ME.THE IGNIGHTER IS EASY TO CHANGE.ENOUGH SAID!!!!!
Posted on Nov 08, 2008
meBNme
  • 334 Answers
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Posted on Jan 19, 2009
duane_wong
  • 6826 Answers
SOURCE: INtertherm natural gas furnace
I would bleed the lines of air if the unit hasn't run for more than a few weeks.
If the flame starts up, but shuts down, a thermocouple or electric eye is erroneously not reading the flame, and it is shutting down for safety reasons.
If you would provide the model number I will look up more specific technical information, if you desire.
Good luck on this.
Posted on Nov 06, 2010
hvac1960
  • 2133 Answers
SOURCE: original problem was circuit breaker
Normally blower should run first and then only furnace will work. check with blower contactor.
Posted on Dec 06, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: NEED MANUAL FOR DUCANE GAS
go on line
Posted on Dec 27, 2010
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Light flashes 4 times
ignition failure. insure air pressure switch closes, hot surface igniter is getting 120volts. check continuity on hot surface igniter, make sure all gas shut off valves are open and gas valve is turned on. make sure there is no blockage in the exhaust
Apr 18, 2014 | Goodman GMS90703BXA Heater
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Ducane furnace gas burner runs one minute shuts down
If this has an Hsi Ignition its time to have a tech check it out and replace
Feb 13, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Ducane furnace is always problem with gas valve lockout at fault code blink two times.
use sand paper clean that flame sensor that should take care of your problem
Dec 28, 2012 | Heating & Cooling
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
