Question about 2003-2006 Ford F250 F350 SuperDuty 6.0 Diesel 8 Bed Extended Cab Gi
Ok, when the truck starts it runs for a second, then it well turn off.. we start it again and it goes click, click.. we tried the battery's both are fine.
    Champion:
    Scholar:
  • 227 Answers
As far as I remember there are safteys in place to shut them down if there are turbo problems. to diagnose this you will need proper equiptment. I'll have to refer you to your local repair shop specializing in Deisels.
Posted on Oct 23, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a 2000 Saturn sc2 that the anti theft lockout has been activated. I was able to get it running, but then it stopped trying to turn over again. HELP
Do a reset or relearn. Reset is turn the ignition on for ten minutes, off for 30 seconds. Try to start. Relearn is three times this. Try to start after the third time. Have a battery charger on it. Voltage goes to low, you have to start over again.
Mar 15, 2015 | Saturn SC2 Cars & Trucks
97 dodge Dakota sometimes when starting I hear a click then nothing if I turn the key again it starts
The starter solenoid is going bad. Check for voltage at the solenoid when u first start it and if u have voltage and it clicks, replace entire starter
Dec 12, 2014 | 1997 Dodge Dakota
Came home last nite and everything was working fine. This morning I turned the key to start and heard a pop either under the hood or under the dash . Now I have no power to start, no headlights, no...
Have you tried jumping the car yet? What have you tried so far? I would get someone to jump it real quick. Theres other ways to see if battery is dead but a quick way is to get a jump then tell us what happens. Good luck-
Aug 18, 2014 | 2001 Ford Crown Victoria
My lumina will jump start and starts several times then goes dead with clicking noise
I would say if the car stays running after u jumped started it I would replace the battery
Jan 11, 2013 | 2001 Chevrolet Lumina
Car was running fine turned it off then tried to turn it on again and there was no power or anything. Checked battery and has a full charg
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | 2010 Ford Edge
Door ajar clicking on off
when you turn the key do lights on the dash come on before trying to start? if it goes click after you turn it further than to on then it sounds like a dead flat battery. get a jump start and let run for 15 mins-half an hour then turn it off and try again. if it doesnt at least crank then its likely a battery that cannot be saved and needs replacing.
Oct 07, 2012 | 2004 Dodge Ram 1500
I see on here where u have answered questions about ppl trying to start their durango and just get a clocking noise. Ok so here goes....my car for a while because my battery was almost dead and then dies...
If you have a new battery and it keeps going dead, then either you have a bad battery or the alternator is not charging properly. Altenator not charging could be either a bad alternator, loose belt, or bad wiring coming from alternator.
Dec 23, 2010 | Dodge Durango Cars & Trucks
My buicks battery has just died. When I jumped it it goes to turn over for a second with a click and then dies down, but all the lights come on. How do I know if its the starter alternator or battery
if the lights are bright and you hear a clicking and your heat blows good, the head lights are still real bright after trying to start a few time replace the starter (you can try to hit the starter with a hammer otr somthing heavy a few times and then try to start if it sounds better or starts replace the starter) if the battery goes dead try to jumpit if it starts then dies after a few min its the alt if it starts runs good and you let it run for about half hour shut it off and it wont restart rite away its the battery.
Jan 01, 2010 | 1990 Buick LeSabre
(ENGINE won't TURNOVER) Just a "click" then nothing...
How old is your battery? 1st thing to check is connections at battery and starter. Make sure there is no corrosion, clean connections with fine sandpaper, make sure connections are tight. If dirty or loose connections exist, you won't be able to start or jump your car. If connections check out ok, pull the battery out and bring it to a parts store for a free check of it's condition. If it's bad, again, you may not be able to even jump start it. If battery charge is good, and condition ok, check your starter. You can also get a free check if you remove it and bring it to a parts store for testing.
Oct 03, 2009 | 1998 Ford Escort
2001 dodge ram 1500 wont start
yur not supposed to and no yu dont need to reset them to the best of my knowledge my truck a 97 dodge ram 2500 v8 sat for like 8 months dead battery and had no problems but yes disconecting negative will remove power from the computer message me back with any questions
Jul 02, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2003-2006 Ford F250 F350 SuperDuty 6.0 Diesel 8 Bed Extended Cab Gi Logo
Top Gibson Vehicle Parts & Accessories Experts
Marvin Steele
charlie rodriguez
charlie rodriguez
Andrew Taylor
Andrew Taylor
Are you a Gibson Vehicle Part and Accessory Expert? Answer questions, earn points and help others
