Question about Frigidaire Over-the-Range Microwave
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
  • Official Brand Answer
  • 4,342 Answers
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Posted on Oct 23, 2013
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
Jan 10, 2018 | LG Microwave Ovens
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
Frigidaire microwave key shows a lock and no keys work
Here is a previous answer that might be of help.......
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
Jun 07, 2016 | Frigidaire Microwave Ovens
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
GE microwave that will not stop beeping
he most likely cause of this problem is a keypad on the control.
You can try the stop/clear keypad to silence the beeping.
You can put the controls into child lock and see if the intermittent beeping stops. The instructions to turn the child lock feature you have it in the owner manual . The child lock disables most keypads.
otherwise replace the control board.
God bless you
Feb 08, 2013 | Microwave Ovens
Goldstar microwave GMV 1540TW locked
From the handy owner's manual here:
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 06, 2011 | Goldstar MV-1526 Microwave Oven
Lock function reset for model JMV8208BAS
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
I need to know how to unlock it
The Child Lock is on.
Your owner's manual covers it. If for some reason you don't have yours, you can download it free here.
CHILD LOCK
You may lock the control panel to prevent the microwave from being accidentally started or used by children.
Example: To set the child lock.
1. Touch STOP/CLEAR.
2. Touch and hold START more than 4 seconds. LOCKED will appear in the display window with two beeps.
Example: To cancel the child lock.
1. Touch and hold START more than 4 seconds. LOCKED will disappear and you hear two beeps. At this time the oven is ready.
Dec 13, 2009 | Goldstar MV-1501 Microwave Oven
Frigidaire Over-the-Range Microwave Logo
405 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
